[WA] pics.WTS.. NOS sportsmen fogger kit $180Shipped!
Old 09-07-2012, 03:16 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
1 .also have a NOS SportsMen fogger Kit (no bottel or Hard lines) easy and cheap to get parts. $180 you get!
8 fogger nzls
16 jets (180 hp Hit at 7psi fuel 900psi nos) have 2 other sets 16 jets ea set
this set of snds have never been used..still new (they have been installed only!!
2 nos snds
2 fuel snds
4 dist blocks 2 fuel 2 nos
(this was on my accel super ram) so you get the hard lines for it
and alot of small parts and hand book that comes with this kit.
easy to set up and use. $180 shipped
Price it out guys..it's a deal!
3.Oil cooler this is a big one Guys holds almost 2qts of oil size 12AN fittings
made BY C&R, cost is over $400 new
give it away for $60 shipped
this is first 48 states. first ill take it gets it
Pay pal is Good add the 4% paypal fee
Old 09-07-2012, 04:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
what condition is the driveshaft in? dents dings, balanced at all, u joints ok or need replaced? I'm interested.
Posted from Thirdgen.org App for Android
Old 09-07-2012, 06:10 PM
Re: WTS Aluminum Drive Shaft $100 shipped NOS foger kit $180
handling marks and some dust. it's used but from a stock camaro. i had it for a back up but never used it. got it from hawks.($150)+ shipping, and just have it sitting.no dings all GM stickers are still on it. drop in. has sold to me from Hawks.
wil try to get a pic up in a few..
Old 09-07-2012, 09:17 PM
Tibo's Avatar
Car: 1991 Z28 Vert
If it looks good in pics, I should be able to take it off your hands.
Old 09-08-2012, 11:37 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Axle/Gears: 4th gen 10 bolt 3.42 posi
Definitely interested in the Nitrous setup. What would I need to put it on my Superram? I already have a bottle.
Old 09-08-2012, 08:34 PM
you would drill and tap your top box, like i did. easy easy
you can see in this shot. the nozls fit over the runners,and spray down into them,
you do get the hard lines for this set up. im sure you can make more. they are easy. to make.
the 2 shots also show the way to set up a super ram with a fogger. (even lay out on the 2 sides) you can set them up anyway you like.
just buy 2 silnds and you spent more the the $180...
sorry for the dust..been sitting a few years in my shop when pics was taken
and if you want to remove the kit you plug holes,with 1/4 pipe plugs..they only go in 1 way. and not all the way in..how easy and simple is that, price it out it's a steel! the sale price is less the 6 fogger nozls.. !
Old 09-08-2012, 08:49 PM
budfreak1's Avatar
Originally Posted by articwhiteZ
you would drill and tap you top box like i did. easy easy
So it's ready to hook up and I don't need any extra parts other than bottle and the lines to go from bottle to solenoids, correct?
Old 09-08-2012, 09:34 PM
you might need to replace a hard line. i will send ss hard lines with the Kit.
the kits sell with just yellow zink plated lines.i replaced every thing with the nos ss lines. you can buff them out to a chrome like finnish.
all the brass fitting you get from any auto parts shop. anyplace(if you need them).when replacing a hard line you need them also.
look at the spacing i have them set at.
look how the kit comes (will ship it put together) for the most part.
will send the TP SAFETY (THINK TPS) but micro switch. see pics
you could install this in one afternoon. you will get everything that comes in a $700 kit but (bottel and hard lines) (hard lines are for a super ram)
and in that case.. yes you get the hard lines. and a few more parts.
you can get more hard lines for this Kit from Summit for under $40 in ss and for reg steel lines under $30 ya only need a few for back up will send what i have. left lines are sold 1 foot long. this kit you only need them 6" to 8" inch long. so you see you always have back up lines left over.
you can flair them your self or take them to a hose shop and have them do it.. cheap!
let me know...
Old 09-08-2012, 09:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Any pics of the drive shaft?
Old 09-08-2012, 09:40 PM
budfreak1's Avatar
I have a superram on my car now and I have an unused 4 & 6 cylinder fogger nitrous kit here that is complete, so I figure I should be able to throw it right on and not need anything. Does it only come with 180 HP jetting? Where does it tap in for fuel? Does it have purge?
Old 09-08-2012, 10:04 PM
pics of drive line just dusty
clean stripe is just that, a clean Spot..think from zip tie.
stock steel one on the right from 92 Z28.
close up
Old 09-08-2012, 10:26 PM
you can tap into your fuel return line.
i have alot of jets (a few bucks more)
Purge i do have one but (a few bucks more)
if you have a Kit now you Have the parts for a Purge (nos silnd) just need one.
of you can use one to one (2 for Purge) in front of your other 2
better look at the Nozls you have now, do they spray at a 90deg angl
shooting down into your Runners..they make some many diff ones.. just so ya know.
Jeff
Old 09-08-2012, 10:36 PM
budfreak1's Avatar
I'd like to have some jets for between 100-125 HP, because I am still stock motor right now. You can keep the 180's.
The kit I have now is a ZEX, so they are all in a box and I'd prefer not to mess with it.
Why do you have 2 fuel solenoids and 2 nitrous solenoids? Couldn't you get away with just 2 instead of 4? I'm trying to understand the setup, as it is hard for me to put it all together in my head through the pics, plus my knowledge is not 100% on nitrous yet.
How much for the kit with different jets and purge?
Old 09-08-2012, 10:51 PM
this set up is better for 100hp and up set ups.
you have a fuel and Gas supply on ea side of the motor.
you can get the jets you need from NOS/Summit. i dont think i have anything smaller then 180 Hit. would have to Look at my jet sets.
look at the pics i posted, ea bank is set up to spray. and to get a good flow. you need that many solenoids. ea one only flows so much.
and you need to flow enof that the jets you use slows the flow. and not the supply... you run nos by a set pressure. same with the fuel.
and you run that flow upto your Jets.. if you dont, flow enof... the jets will not do the work, and you will never get it set at the HP Hit you want,
hope that helps
Old 09-08-2012, 10:55 PM
budfreak1's Avatar
Re: pics.WTS Aluminum Drive Shaft $100 shipped NOS foger kit $180
Ok, I get it. I sorta figured it was a flow issue.
How much with the jets I want if you have them and purge?
Old 09-08-2012, 11:06 PM
no more for smaller jets. i would just swap them out (if i have them)
add $30 more for the Purge. it's also new used 4 or 6 times years ago.
was on this set up.
if i have them (Jets under 125hp set up) add another $35
they run $8.00 ea new, and you need 8 for fuel and 8 for NOS
if you want the jets in kit now and the lower HP Hit jets,
Old 09-08-2012, 11:09 PM
budfreak1's Avatar
was on this set up.
I won't want the 180's, I have no need for them anytime soon.
Ok cool, thanks for all the info. man. I am supposed to get paid for a job tomorrow, and then I'll hit you up.
Old 09-08-2012, 11:13 PM
all over view..so ya get a Idea
(8 years of dust sorry)
Old 09-08-2012, 11:15 PM
budfreak1's Avatar
Wow, now that is an intimidating sight when you pop the hood lol. Love it!
Old 09-09-2012, 10:48 AM
still up for grabs
Old 09-09-2012, 11:37 AM
budfreak1's Avatar
Just waiting to get paid and figure out what I have to play with. I should be in touch later today with any luck.
Old 09-09-2012, 09:45 PM
BTT
Old 09-10-2012, 08:55 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Ok, driveshaft looks in good shape and you say its in good shape too, so I'll take it for $100 shipped. Pm me with payment info.
Old 09-10-2012, 10:58 AM
karistanker's Avatar
Car: 89 Sport Coupe Vert (IROC-Z clone)
Engine: 383 Stroker TPI
Axle/Gears: 2.73 (3.73's awaiting install)
If Tibo backs out on you I`ll take it. My cash is waiting on you! I actually need it.
Old 09-10-2012, 07:09 PM
he's in front of you. with the ill take it.
i have sent PM with Paypal info... i always Give them 24 Hrs to do there thing.. so hold tight. and will let you Know..
and remember there is a fee for the Paypal thing..thats them Not me..
Jeff
Old 09-11-2012, 01:01 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Money for driveshaft sent
Old 09-11-2012, 06:16 PM
just got home from work,tue.9/11/12 funds are good it's going out wed the 12th.
will get you a tracking # about this same time (home from work) wed the 12th.
would have sent it out today...but i was in bed when you sent it..LOL
COULD NOT check my paypal till i got home from work..
Jeff
Old 09-11-2012, 11:53 PM
got it dropped off tonight. it will ship off in the AM,you should see it fri this week..3 days
your tracking info fedex
468428615094311
Old 09-21-2012, 04:32 PM
Re: pics.WTS.. NOS sportsmen fogger kit $180Shipped!
BTT
Old 10-05-2012, 12:44 PM
btt
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
junior419
09-22-2015 03:19 PM
1Aauto
Sponsored Vendors
09-10-2015 02:02 PM
1Aauto
Sponsored Vendors
09-02-2015 01:50 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
Quick Reply: [WA] pics.WTS.. NOS sportsmen fogger kit $180Shipped!
