Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
SLP Headers 1 3/4"
Old Mar 19, 2001 | 10:23 PM
The Man's Avatar
SLP Headers 1 3/4"
Does anybody have pics of these for a 3rd Gen? Does the driverside header have a dent in the primary tube to clear the steering shaft?
Old Mar 19, 2001 | 11:05 PM
The ODB's Avatar
they are shaped similar to TES but look much better.
mine didn't come dented, and I used a grinder to clearance for the steering shaft.
Old Mar 20, 2001 | 12:23 AM
FTC's Avatar
FTC
i used a blowtorch to heat it up and gave it a couple light taps with a hammer to make the right clearance.
Old Mar 20, 2001 | 09:40 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Mine aren't dimpled, but I didn't have a clearance problem with the steering shaft on mine either. SLP told me I might have to put new motor mounts if I encounter this problem.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
[This message has been edited by IROCZZ3 (edited March 20, 2001).]
Old Mar 20, 2001 | 04:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Some people have steering shaft problems, others dont. Ron84ZZ4 came up with the solution of moving your steering shaft over a tad if it hits the headers. Dont dent them if you can help it.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 26, 2001 | 05:42 PM
LIFORM383's Avatar
I have the 1-3/4 inch off road headers on my car and I experienced no clearance problems at all. I am very happy with the fit and performance.
Old Mar 26, 2001 | 06:32 PM
91RedBigFinZ's Avatar
i had a problem even with the new motor mounts. i just grinded the steering shaft down. Doug
'91 Z28 - 50,000 miles. All power options leather. 350 TPI:
K&N; Fastchip; Airfoil; Custom 'Ram-Air'; SLP Headers; Slp Runners; Borla Catback 50% open; Dual factory Cats; Poweraid TB spacer; March underdrive pulleys; Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs; manual fan switch; TB coolant bypass; Pirelli P7000 Z245/50/R16 all season tires; Energy suspention motor mounts.
S Cobra Radar Detector; Z28 SS Floormats
Old Mar 27, 2001 | 08:10 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I also had to clearance for my steering shaft. I had to grind the post on the end of the #3(I think) sparkplug to get it in. Other than that, they went in pretty easy.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 27, 2001 | 08:45 AM
Ken88GTA's Avatar
Kevin is right, don't dimple the tube if you can help it.
I put in new motor mounts when I installed mine, had no clearance problems at all.
Ken
[This message has been edited by Ken88GTA (edited March 27, 2001).]
Old Mar 27, 2001 | 06:39 PM
The Man's Avatar
Thanks everybody!
MY87LT
Jun 7, 2016 09:47 PM
83RDRACR
Mar 26, 2016 08:13 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
alpine247
Sep 16, 2015 05:25 PM
