Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Accel or MSD???
Old Jul 5, 2002 | 10:41 PM
project200RS's Avatar
Accel or MSD???
I have a 92 camaro RS with the 3.1 v6... mods are: custom cai, K&N air filter, TB bypass, and bosch platiums. Within the next year i plan on getting a high flow cat (catco), dynomax cat- back with 2.5 mandrel bend, valve adjustment and pulleys. I figured after the pulleys i would need a better ignition system but even if not i still want to upgrade my spark. So which is better, Accel or MSD, I've heard good things about Accel, and also bad things about accel... the same for MSD, so for the money what ignition system would be the most reliable , safest and best.
Old Jul 5, 2002 | 11:37 PM
Tom Keliher's Avatar
Everyone has their own opinions. But FWIW, I have been using Accel ignition products on my Formula since 1993 without a single failure, except for wires I burned on my headers. I use Accel distributor cap; rotor; distributor module; electronic coil; spark plug wires.
Old Jul 6, 2002 | 11:45 AM
iroc22's Avatar
I like my MSD ignition products better than my Accel.
Old Jul 7, 2002 | 11:58 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I have had very good luck with MSD, just don't use Hypertech and you should be good either way.
Old Jul 8, 2002 | 12:47 AM
firbird's Avatar
i hate my 8.8 accel wires i need some msd wires. so fare i burnt a few of them but that does not bother me because it was my falt but what pisses me off about accel is they dont really stay in good and when you try to push them in the terminal just gets pushed back and you have to shove it back up
Old Jul 8, 2002 | 01:47 AM
ronterry's Avatar
Car: '94 Corvette
I do like the Accel black race wires. I think there around 150 ohms per foot, and the boots can handle a bit more temps.
Me....I'm currently running MSD Super Conductor 8.5mm with DEI boot sleeve's...
MSD Pro-Billet socket cap distributor
MSD blaster 2
MSD 6AL
Hell, I even made a custom set of 8.5 to put on my Impala over the holiday. (BTW: It's a 3.8 V6, not sure if your 3.1 V6 looks like it?)
Ron
Old Jul 8, 2002 | 09:48 AM
Brian'sIROC's Avatar
I am also looking at a new ignition, either MSD or Accel. I'm leaning towards the Accel because it's smaller, comes with the GM style connectors and comes with a coil. With the MSD you must buy the harness and coil seperate. Unfortunately it seems that everyone has a MSD box. Not many Accel people.
Old Jul 8, 2002 | 10:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I bought the MSD 6AL just because it seemed like most of the racers at the time were using 'em. Both boxes have their good points and bad points. Plus, I seem to favor MSD anyway, so the 6AL box seemed natural. No problems with it, it's been on for two years.
Old Jul 8, 2002 | 04:02 PM
bigbrianiroc-z's Avatar
dont wast your time and money with accel. go with MSD their stuff is alot better.
Old Jul 8, 2002 | 05:10 PM
Any personal experiences that would make you say that? have you owned an Accel 300+ ignition?
Old Jul 9, 2002 | 09:36 AM
Car: 91 RS
Engine: 350 TBI
I had an accel set-up on my 89' Caprice. Good parts, but making those 300+ Race Wires fit my engine was a real pain in the ****. I don't like to see the term "fits any V8" on the box any more.
Old Jul 9, 2002 | 05:53 PM
ronterry's Avatar
Car: '94 Corvette
I heard that !!! Is it me or do they always make one that is way to short, and the rest a foot to long?
I now buy bulk wire, and cut my own. I think the Impala probably set me back around 50 bucks.
My 350 I used a universal cut to length set.
Ron
Old Jul 10, 2002 | 05:10 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
MSD all the way. i have screwed with mallory but msd is definitely my fav ignition manufacturer. however, their prices on plug wires were too steep for me so i went with accel 8 mm spiral core wires.
Old Jul 12, 2002 | 08:08 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
good ignition?
I've a 84 z28 carbed 305 h.o. it was totally smog equipped, called edelbrock and bought their cam/lifter setup, 600cfm carb, performer intake, now for the distributor,, They said I'd have to up grade but didnt say why, called em back and the reason why was because of the computer controlled smog junk. All the smog junk is gone and Iwent with the accel unit, good voltage and fair priced. I seen msd and accel advertise their polished billet unit's but why pay for the polish and shine that your not gonna see! THEEXTRA MONEY YOU SAVE COULD GO FOR SOME MORE WORTHY PERFORMANCE ITEMS. Both msd and accel are good, and everybody has a prefference for one reason or another, mine was cost and budget, Im happy, good luck
Old Jul 12, 2002 | 08:55 PM
ronterry's Avatar
Car: '94 Corvette
I bought a MSD Billet distributor for a couple of reasons non involve looks.
For one I got a Socket style to get rid of the bulky HEI unit (14" air cleaner, it gets tight) and run a remote coil.
There was timing issues at high RPM's, since the HEI unit I had was pushing 20 years old why chance another used unit. The rod begins to wobble if there is to much slack it causes the timing to jump around a bit.
Over all timing!!! Adjustable stop bushings (Adjust the length of the timing curve), thicker shaft & ball bearings to prevent shaft flex. The list is long but distinguished
BTW: They want you to run a distributor with a vacuum advance. Your fuel economy with suffer without one. I used to buy used pre '80 HEI for $25-40 bucks that are equiped with vacuum advance. Sure it's cheaper than my 180 dollar billet unit, but there real old -- pre '80???
Ron
OK OK OK they are pretty also :sillylol:
Old Jul 13, 2002 | 06:21 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
ok i have something bad to add (hey im a poet and didnt know it)
i just bought an MSD Blaster coil and MSD plug wires for my Formula yesterday and have had trouble outta both already. first we'll start with the coil. im drivin down the road (on the military post i live on) when my car starts to buck and miss and run like ****. so i pull over with the engine running and look under the hood to what to my wonderin eyes should appear? MY FU(KIN COIL IS SPARK LEAKING. and all i see is a shower of sparks. so i shut 'er down and remove it. now we'll move on to the wires. today my car starts acting up again. so when i get home i decide to put my old plug wires on due to MSD's track record thus far. shure 'nuff, put old ACCELS back on and car runs like a champ. cant get money back because its electrical. im p!$$ed!! and, to whom it may concern, yes, i am a MECHANIC so the work was done right.
Old Jul 13, 2002 | 08:23 AM
Slade1's Avatar
GM has a good performance set, albeit costly, that probably will give you the least amount of complaints like a good old stock set. On top of that you can get logo's on them like GM Performance/Chevy bow tie and in blue red too. Not hard to track down too since they are after all from GM Performance.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
efiguy
Sep 27, 2015 01:30 PM
