how are Edelbrock aluminum heads???
im just looking to upgrad from the heads i have and i AM on a budget the Jim Pace GM performance parts catalog has a set of Edelbrock aluminum heads for about $1100 dollars complete, say's there for 87 to 95 5.7L engines w/ centerbolt valve covers and work w/ TBI or TPI engines and they have 60cc chambers...
Thanks - Don
Thanks - Don
They're a good head for your money. They don't put out ground pounding flow numbers, but they have excellent quality and can perform.
Are you set on aluminum heads? If not, Vortec heads are really cheap and will make tons of power.....
i just bought the aluminum edlebrock performer heads. they are go'n on later this week i'll tell u what i think of em. the only reason i bought em was because they are $1,100 heads i got em new still in the box for $800 from a fellow 3rd gen. driver
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I own a set of Edelbrock aluminum heads, for my 383 Tuned port and I have not had any proablems.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
1 Post
Car: 1989 Iroc Z L98
the stock vortec cast head (the newer design with 30* exhaust back cut) out flows the edelbrock performer head. they are pitiful heads and are not worth the money. if it were me for that price range, i would be looking at AFR heads. they make great low end power and have a setup that you are looking for.
1 Post
Originally posted by bluegrassz
how does the dart pro 1's compare to the afr's?
AFR 190 heads
355ci sbc
9.5:1 compression
holley 750
afr intake
1 5/8 headers
430 horsepower 470 ft lbs of torque
not bad at all :lala: :hail: :hail: :lala:
1 Post
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
new car craft
350SBC
10:1
edelbrock 750
274xtreme cam
1 3/4 headers w/flows
RPM intake
vortec heads
442hp/452ft lbs
NOW THATS CHEAP POWER!!!:hail: :hail:
If i dont build my 400 in the near future, i will be getting a set of these heads. also, look at comp cams web page, they have a dyno page now with their cams, look at how much power they arent getting out of their engines cause of SH#$## heads.
350SBC
10:1
edelbrock 750
274xtreme cam
RPM intake
vortec heads
442hp/452ft lbs
1 Post
just make sure you know how much machine work you are getting into giving these heads a big lift cam. there is an article in a recent CHP, so beware that the stock springs take .45 lift i believe tops. also, 10:1 on cast iron heads is in danger of detonation so beware of that also. i have tinkered with the idea of leaving my vortec heads on my 350HO and seeing what kinda horsepower i can crank out of it...
1 Post
Originally posted by LilJayV10
new car craft
350SBC
10:1
edelbrock 750
274xtreme cam
RPM intake
vortec heads
442hp/452ft lbs
new car craft
350SBC
10:1
edelbrock 750
274xtreme cam
RPM intake
vortec heads
442hp/452ft lbs
1 Post
Engine: 406 Roller
with that kinda power, and a 6speed, i think i'd go cobra huntin...or maybe a Zo6:lala:
1 Post
Car: 1986 Z28
Engine: 355
Transmission: th400
To run the XE274 cam you dont' need any machining for valvesprings, just the right ones, and they are less than 50 bucks.
I know the springs that go along with the XR270hr camshaft(the double ones) fit in without machining as well. Beings that there's no reason to put 1.6's on there, ther's no reason for machinework to make them fit.
The stock springs on the vortec heads are garbage, they dont even have a dampner on it. pull em off and throw em out.
In my Opinion they are the way to go. i've seen more vortec headed 12 sec rides at my local track than AFR headed ones
for the amount of power you guys want to make the vortecs would be the sensible choice. they make good power for a minimun investment. if you want 'exotic' heads so you can impress your friends with receipts instead of your subpar timeslips then go for the AFR 190's(throw on the 1.6 roller rockers while you're at it. it appears to be a trend)
if you guys need $1,200 heads to make 400 horsepower you either have money to burn or are just totally clueless.
