Just for You Centerbolt wire looms, review
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Got the looms from Summit for 41.69 shipped to my door. The kit was complete and high quality. Manual dexterity is a must, holding four plug wires in the bottom part of the loom while putting the top part on then starting the screw, while holding the nut underneath in place. A little scotch tape helped hold the nut in place. Cleaned up the plug wire routing nicely. I have pictures if you want to see some.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Rob...Do you have headers on your car? If so how is the clearance running the wires over the valve covers?
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Mike
I have the Made for You wire looms on my car too, and I'm running MSD 8mm's with SLP 1 5/8" jet hot coated headers. The routing is pretty good for keeping the wires away from the headers w/ all 90* boots, but I got some of those MSD wire holders that hold two wires together for the 2 and 4 cylinders. I think I used them on 1 and 3 too. I'll try to get a pic later on. All in all they work nicely. I didn't use the 3 wire loom, only the 4 and 2 on each side because the 3 wire loom would have made the #s 6 and 5 cylinders come down into the exhaust primary for each side.
-Jason M. 1991 Camaro Z28
"Its Blue."
"Its Blue."
Guest
Posts: n/a
I also have them, they were a little pricey but I really like them. Here's a pic of mine with MSD 8.5mm Super Conductors.
87 IROC
350 TPI 5-speed
- Edelbrock Aluminum Heads, LPE 219 Cam, Super Ram, SS Wheels, Graphite Leather, etc. Click here to see the rest.
-=ICON Motorsports=-
[This message has been edited by Jarod87IROC (edited October 08, 2000).]
87 IROC
350 TPI 5-speed
Car: 87 camaro iroc
Engine: 5.7L
Re: Just for You Centerbolt wire looms, review
Sorry to dredge up an old thread but I would be very interested in seeing some pictures of anyone that has done this.
To anyone that replys I appreciate it
Glowsock
01-09-2017 04:06 PM
MoJoe
09-24-2015 09:12 PM
