Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Which cam?????
Old Sep 30, 2002 | 07:17 PM
1fastz28's Avatar
Which cam?????
I have a 91' Z28 and am i the process of building a motor for it. It is a 406 with summit 6" h-beam rods, stock crank (cleaned and magnafluxed), and wiseco 10.8:1 compression. I have afr 220 heads and plan on using an edelbrock intake base, runners, ported plenum, 58 mm throttle body, and holley 30 lbs injectors. What cam do you recommend for this setup and do you think the tpi intake will be suited for a 406?? Do any of you guys have a combo like this?? What kind of power should I expect?? I'm new to building a fuel injected motor. Please HELP???
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
