does anyone have a setup similar to this one?
here is the proposed setup that my cousin has lined up for his 86IROC:
350 crate motor--base
Comp Cams XE274hr or XE282 camshafts
AFR 190 heads
1.5 rockers
Edelbrock RPM intake or AFR matching intake
3.73 gears
automatic w/shift kit
there is also gonna be a 125 top shot kit of juice when needed. but bascily, im courious about the engine itself. thanks
PS, any dyno numbers or track #s would be greatly appreciated.
AFR 190 heads
1.5 rockers
3.73 gears
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
355 10:1 Manley Forged pistons
4340 Pro Line/Summit forged steel crank & rods
Weiand Stealth dual plane intake
Speed Demon 750DP
Comp XE274
1.5 Comp Pro Magnum roller rockers
AFR 195(64cc) heads straight plugs
HEI with MSD Blaster SS coil and 6AL
Very fun motor with a nice lopey idle!Fast enough to run with most anything you will roll up next to on the street.No numbers yet but soon to come!I would go no bigger than the 274 cam on the base 350 crate motor due to the lower CR unless you plan on milling the heads down to bring it up to around 10:1.Otherwise I would recommend the 268 cam kit.
Speed Demon 750DP
Comp XE274
