Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
CAM for SuperRam
Old Nov 8, 2002 | 06:19 PM
primo's Avatar
CAM for SuperRam
I am building a 383 motor for my TPI Camaro, the engine builder had my AFR190 heads flow tested and came up with the following cam specs:
CAM motion
112 centerline
IN / EX
225 / 231 Dur at .050
0.554 / 0.560
Rocker Ratio 1.6
My question is, will this be ok for the superram and the computer, what can I expect
from this engine. The cam is installed and the engine is ready to go in the car.
Thanks for you answers,
Old Nov 8, 2002 | 07:01 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
It looks good based on those specs. I'd expect high 11's at 115 MPH or so, when it is tuned.
Old Nov 13, 2002 | 10:48 AM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
the compuer isn't gonna be ok if you use the stock PROM, you need to start getting into PROM burning so you can tune it to the cars specs.
Old Nov 13, 2002 | 02:06 PM
Brian'sIROC's Avatar
A few of the lingenfelter cams are designed to work with the super ram
Old Nov 13, 2002 | 02:33 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
thats correct, the LPE 219/219 cam is a perfect choice for the super ram.
Old Nov 13, 2002 | 11:06 PM
88IROCARMY's Avatar
I'm in the same boat with S/R and cam selection.
I have the S/R and a ZZ-9 cam that I plan on using in a 355 SBC.
I'm intrested to know if any one has done this intake/cam combo and their results.
Also topped with AFR 190s
Old Nov 13, 2002 | 11:30 PM
BuckeyeROC's Avatar
I have that combo but with the LPE 219, results are in my sig. below. Keep in mind that it has not been tuned yet, I hope to get some dyno time this winter for tuning.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
