Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
cam help!!!
Old Dec 10, 2002 | 09:05 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
cam help!!!
i have a LB9 305. like any other 305 owner, i wanna make it faster. i know 305's are not too cam sensetive, and needa a more radical cam to perform because of the small bore. i was wondering what the best power combo would be. (I'm on a budget). I've been looking at GM LT4 kit. LT4 hotcam .525/.525 lift with matching springs retainers, etc. Will that work good. I've seen it done in a camaro magazine with a 305, but all i know is tat they ran 13.02 on Lt4 hotcam. I don't know what else they had in it. thanx Aaron
Old Dec 10, 2002 | 09:18 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
The LT4 hotcam is way too big for a 305. It's a pretty wild cam in a 350, let alone a 305. They are easy to overcam. I'm guessing it's a roller block since you were looking at the LT4 hotcam. I think CompCams makes an XE262 in a roller version (possibly XE262HR?) but I'm not sure. If not I would look for something like the 262 in terms of lift and duration. The XE262 is a great choice for a 305. I wouldn't reccomend anything bigger unless it was a strip only car (but you would probably have a 350 or bigger then...)
Old Dec 10, 2002 | 09:30 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
respond
hey. i read an article on 305's that say that for best performance... the 305 needs a high lift cam. max lift recomended was .530/.540. with very good springs. i know the LT4 has good daily driver specs and works great with a 2400 converter. after reading that articel and you're response... I'm confused
Old Jan 23, 2003 | 03:37 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i'm gonna get the LT4 cam along with the 2400 holeshot tq converter. they seem to be a good combo,
Old Jan 24, 2003 | 09:15 AM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
that's toomuch cam for that lil motor. (lt4hotcam)
if your running a tuned port motor, Comp has some specific cams for them. your best all around choice would be one of them.
i'd think the best one for what you wanna do is something on the lines of their part number.
08-302-8 specs on it are
210/220 @ .480/.480 lift with a 112 lobe sep angle.
the grind number is CC264hr-12.
That's a smidge bigger, and definitly more agreesive than the L98 cams and bigger and more aggressive than the regular lt4 cam.
same 2200 stall converter should do you just fine. a lil computer monkeying to get it running the way you want and your set.
Old Jan 27, 2003 | 05:30 PM
Brian'sIROC's Avatar
A ZZ4 cam would be a good choice for a 305. You would definately have to change the stock springs out. You can get a ZZ4 cam for $175 from Scoggin Dickey.
Old Jan 29, 2003 | 02:55 AM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
I've got a comp cam for sale....Hyd.roller 210/218 @ .050 487/495
it worked great in my 305 TPI ...Has about 100 miles on it
BC
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
