1 A Auto healiners??
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
Has anyone purchased one yet or heard anything about them becuase i need a new headliner and it looked real durable. My old headliner was completely distroyed so i just threw it out. If you guys could help me out i would appreciate it a lot. Thanks guys...
Heres the link to the headliner:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875448463
I just got one from them about a week ago or so, i haven't put it in the car yet because i need to fix some rust by the t-tops first, but basically its just a flexible plastic, should last a long time, WAY better than the factory one if you ask me. Hope this helps.
Car: Check The Sig
u know, i dont understand y they never made the t-top headliner just plastic? theres not much to the headline itself? at least the leading edge where the t-tops meet the headliner? i wounder this as i look up and see my headliner fall apart.... i would like to get there headliner too...
Car: '91 Formula
Transmission: TH350 built
chieck out this site. I havent used them but it looks interesting
http://shop.1usa.com/aabest/merchant...?id=299&step=2
Car: 1987 IROC-Z
Engine: Carbed 355
The more i look at the other company im I'm begining to like the AA Best company's offer. It is like three dollars more and has a written lifetime warrenty...May not be a factor but still always good to know that you have it. While once i have the money laying around ill buy the headliner and see what happens. Thanks a lot guys
Car: 67 ss 89 rs
Engine: 327 350tbi
Transmission: 5speed
I put that headliner in a few years ago and it still looks great. I did have 2 problems. problem #1 is there is a clip in the original headliner just above the rearview mirror, the aftermarket one didn't have this. The second problem was my fault, I cracked the rear hatch upper trim that holds the back of the headliner in place. The new unit weighed more than the old one, I should have had someone help me install rather than trying to support it off one screw. My camaro is a hard top model.
I also installed one . Same problem missing clips up front by mirror. I just measured off the old headliner , reomved the clips and epoxied them on to the new headliner . I had another problem , i have a dual map light dome light , but the hole was made for a standard light . So i had to trim the headliner for it to fit right . That was the most time consuming part . My old liner had broken about that point so i couldn't get a good measurment . So i used the dome as a template then cut my hole , i was afraid to cut to much so i ended up installing about 4 times till it fit right .
Linson
10-01-2015 09:50 PM
