Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Porting the Plenum
Old Jan 7, 2003 | 09:19 PM
gtaguy87's Avatar
Car: 1998 Ram Air Trans am
Engine: Ls1
Transmission: 6 speed manual
Porting the Plenum
How much does it cost to get the plenum ported, and what kind of hp does it give you anything?
Old Jan 8, 2003 | 09:03 AM
MdFormula350's Avatar
here are the search results..
https://www.thirdgen.org/techbb2/sea...der=descending
Old Jan 8, 2003 | 11:13 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
If you have a dremel, why not just port it yourself ?
I did the same to mine, worked out very well, you wont get a huge amount of HP from it but it definitly helps, especially since I was free and about 3 hours work.
Here's a link for info...
http://www.gmtips.com/3rd-degree/dox...-port/port.htm
Old Jan 9, 2003 | 12:17 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Here are some other pics from ZaphodB's page http://www.area51.org.il/~zaphodb/gmecm/portedplenum/ ........
/N.
Old Jan 9, 2003 | 12:22 AM
gtaguy87's Avatar
Engine: Ls1
SLP RUNNERS
I have slp runners do i take those off to get to some of the points to port? also do i polish it the same way i do the plenum
Old Jan 9, 2003 | 12:58 AM
gtaguy87's Avatar
Engine: Ls1
Polishing question
Once ive sanded all the grainess off do i start with the emery compount or tripoli. Also where can you get these compounds home depot or something. someone let me know thanks for the help again
Old Jan 9, 2003 | 09:33 AM
SydwayzTA's Avatar
Car: 1986 Trans Am
Yeah it would be easyier if the runner were off to get to the side ports. as for polishing and what not i dont know much about that I just do performance stuff but heres a link for polishing info.
http://www.gmtips.com/3rd-degree/dox...m/pol-plen.htm
Old Jan 14, 2003 | 08:42 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
plenum porting
it is easy to do yourself, u can just remove the throttle body or to be safer, take off the plenum to makes sure the injectors don't such in metal shavings. It gives about 5-15 hp base on stock motor-to 500hp motor. It most improves the throttle response which is nice. you can just remove the air restrictions in the front of the plenum, or smooth out the whole thing. If you wnat to smooth out the whole thing, it takes forever and you have to be sure u don't get into the housings for the alan bolts. you can guy a completely ported plenum brand new from TPIS for about 100 bucks. Which ever way workd for you!
Old Jan 14, 2003 | 10:29 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
I ported the whole thing myself, front to back, took about ummm i dunno guessing around 5 hours total, non stop though, still gotta put it back in, after i get a new egr valve, and new fuel pump.... THEN i'll be able to enjoy it, lol
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
