Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Head and header combo?
Old Apr 20, 2003 | 10:04 AM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I have Dart Iron Eagle heads, straight plug design and SLP 1-5/8 heasers. There is barely enough room to keep from burning the spark plug boots... and thats with the shorty plugs. With standard length plugs the spark plug boots touch the headers!
Does anyone have these heads, and what headers fit well?
Old Apr 22, 2003 | 12:52 AM
txhotRS's Avatar
Almost any chevy small block, especially with third-gen style headers is barely going to have room for anything, the outside dimentions of NEARLY all the heads that you could use are going to only be within fractions of fractions of a inch of eachother... the big difference is angled or straight plug holes... the only thing that I could suggest is SLIGHT tapping in the sides of the headers for a TINY bit more room, and using HEAT PROTECTORS on the plugs..
GOOD LUCK
Old Apr 22, 2003 | 01:04 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
I plan on getting a set of the Ultra Ceramic wires because of this proximity issue with the headers. I'm hoping they solve the problem, or at least make it managable.
Old Apr 22, 2003 | 07:59 AM
slowTA's Avatar
Car: '88 Formula
Thanks for the feedback, I was just wondering if someone happened to stumble across a combo that worked better. I know there was a ton more room with stock heads than with the Iron Eagles, I'm just glad no one said that I should have bought the angle plug heads instead... that would aggrivate me.
I was looking at the ceramic plug wires, but at $180 for the 90d set I kinda want proof that they'll really do the trick.
Old Apr 22, 2003 | 11:13 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Call and ask them... I know they used to have lifetime warrantees on their wire sets.
Old Apr 22, 2003 | 12:43 PM
slowTA's Avatar
Car: '88 Formula
Now why would I go and do something that easy??
Old Apr 22, 2003 | 05:18 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
*shrugs* I dunno...
1984HO
Mar 19, 2021 11:59 AM
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
theurge
Aug 21, 2015 12:46 PM
