Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Accel wire assembly?
Old Apr 25, 2003 | 05:43 PM
Cuno's Avatar
I just purchased a set of Accel Super Stock universal fit wires...they are the ones you have to cut and assemble yourself. The problem I am having is how the heck do you get the boots onto the wires! Is there a trick to it?
Old Apr 26, 2003 | 12:15 AM
Cuno's Avatar
update: I returned them after trying for an hour to assemble one! I said the hell with assembling my own and purchased the pre-assembled ones.
Old Apr 26, 2003 | 03:35 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
The first do-it-your self one is the most fun
What works best is to wet the wire with a little silivia (water works too) and a little on the inside of the boot, then work the wire through. There is technique involved, and it has mostly to do with the colorful array of words thrown at the boot while dancing around wour garage working on eight hernias at once.
Put the connector on the wire after having put the boot through. Remember to cut the wire to the desired length before attempting to slide (I use the term loosely) the boot on to the wire. The accel crimping tool sucks, the MSD one is far superior. It might help to get hold of one as they are much easier and faster to use,with both a cutting guide and a crimper that stays together when under compression in a vice.
When you have finished, you will know true frustration, but it looks much better if you run the wires right with no slack at all. Another hint: cut the wires about 2 inches longer than you think you need. It is easier to trim a wire than to grow it out
Old Apr 26, 2003 | 07:39 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
ya i bought a set of those and returned them to get a set of custom ones. im not going to mess with anything like that till i do my motor swap......
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
tazs2000
Jul 15, 2017 08:44 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
