Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Crossfire computer upgrade?
Old Aug 1, 2001 | 07:02 PM
dowtyt's Avatar
Has anyone heard anything about the computer upgrade that Turbo City sales? It's over $500, so I wanted to see if it's all it's cracked up to be. I have a stock '83 Z28 except for a lightweight flywheel, and soon to come, a Random Tech hi-flow cat. thanks,
Tim
Old Aug 3, 2001 | 12:01 AM
ProblemChild's Avatar
I've been talking to a guy that runs a company called "ghostwheel technologies" that has an ecm upgrade for cease-fire cars using the later p/u ecm and a custom chip. I'll look for his email address tomorrow if your interested. He know's his stuff. He's the one working on the chip for my car which is a mother%*&@&# cause of the swap i did.
Torque is KING!
All pray to the god of grunt! When ye thinkth ye has been whupped than shall ye meet the mighty Buick! For none can surpass her majestic power, and all will yet try. All pray to the god of grunt. For the King of Torque hath arrived!
1. 82 Camaro+ 1. 455" Buick+ 1. N2O plate = YOUR WORST FRIGGIN NIGHTMARE!!!
Da Problem Child
ProbChldR@aol.com
Old Aug 3, 2001 | 01:42 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Do a search on "cross-fire" on the DIY Prom Board. Someone just mentioned a "conversion" to the 8746 (or 8747) ecm for the Crossfire and which solves all the "programming woes" of the CFI system.
Old Aug 3, 2001 | 11:07 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
please do not say cease-fire injection. that is not nice to say to your fellow 3rd genners. and CFI dies off at 4200 rpms stock. and TPI dies at 4600 stock. only 400 rpm diff. and my CFI runs just fine. and its got a very desent amount of power. ill be getting a g-tech soon to prove to you that CFI can make power. man i dislike people like you. were on the same team. OK
thats all i have to say
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000, 1.5" Jamex Lowering springs(pics are before lowering springs, ill get new ones soon).
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
Old Aug 6, 2001 | 06:56 PM
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by RED82TA5.7L:
...and CFI dies off at 4200 rpms stock. and TPI dies at 4600 stock. only 400 rpm diff. </font>
Actually, my TPI pulls like crazy until 5,000 rpm. But all the other things you said are valid.
There are some very good mods available for Cross-Fire (like the X-Ram intake and the ECM conversion that I mentioned above) which can make Cross-Fire perform quite nicely. In fact, I think it's cheaper to make Cross-Fire hit low 13s than TPI on a similar engine.
If you would like a link to a cool Cross-Fire Bulletin Board web site, let me know.
Old Aug 8, 2001 | 09:30 AM
hotpowerandperf's Avatar
The upgrade to a 1228746 computer is definately worth it, but 500 is way too much. You can do this conversion for much less. I can provide information on this if you want.
John
Old Aug 8, 2001 | 12:05 PM
dowtyt's Avatar
Sure I want to know how to do it cheaper. Can anyone tell me specifically how it helps my car? Better gas mileage, more performance, anything else? How? thanks for all the help, Tim
Old Aug 8, 2001 | 12:40 PM
The original 550 computer is very slow compared to the 8746. This increase in processing speed allows for a closer tolerance closed loop operation. The bottom line is you should see an increase in mileage (small.) The performance increase will probably be negligible on a stock motor. The place that the 8746 really shines is reprogramming. The original computer uses one time burn chips.
I guess you really have to decide how much you want to modify your car and weigh that against the inflexibility of the 550 computer. BTW you should be able to make the conversion for 120 less prom. The reason I quote less prom is I would advise you to learn to program you own proms if you choose to make the swap. If anybody wants more info please email me directly @ hotpowerandperf@hotmail.com
John
John
Old Aug 8, 2001 | 04:15 PM
Engine: LT1/350 TPI
well. forget about what i said before. i found a complete TPI system for $450. imin the prosess of buying it. and the CFI somedays it runs good but somedays it runs like crap.
so im going with TPI because they look better and they run alot better. ive seen one run right when it started up and it ran sooo smooth. my CFI runs smooth sometimes but most of the time it rus rough. so. in about 2-3 weeks im going to be a TPI guy. but im going to keep my CFI for maybe an old hot rod or something.
oh, and im sick of people making fun of me because i drive a CFI car.
and it will be a step up from CFI
RED82TA5.7L
For Pictures go to
[This message has been edited by RED82TA5.7L (edited August 08, 2001).]
Old Apr 20, 2023 | 08:43 AM
rizz54's Avatar
Re: Crossfire computer upgrade?
John
I’d like to upgrade my 83 crossfire system. I’m almost done restoring it. Please send me the link
Old Apr 20, 2023 | 12:55 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
This thread is pushing 22 years old but you could look into an EBL if it's an ECM upgrade you're looking for. www.dynamicefi.com
Go to that website and you could also read a thread called "tuning with EBL" under the DIY prom forum.
seiplentz
Aug 19, 2019 06:02 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
edoff13
Sep 11, 2015 03:55 AM
