Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Hmmm... Not understanding this B&M shifter.......
Old 10-16-2000, 08:07 PM
FiReBReTHa's Avatar
My apologies, ive researched all i could,
i have a 91 firebird 305, its auto, (sux) and i wanted to change over to a manual but cost is a Large factor. i kept on seeing this thing about B&M
Is it a manual shifter for Automatics? or how would you classify it?
and how is it setup?
Our autos are
[P]
[R]
[N]
[OD]
[D]
[2]
[1]
What is it on a B&m,
any info you guys can give is appreciated... and how is it to install cause id prob do it at my school with a lift..
Thanx In advance!
Old 10-17-2000, 07:14 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
B&M makes a million products. Are you referring to the Megashifter? It's primary purpose is just to stop you from over-shifting if you are the type of person that likes to manually shift your automatic. I bought it because I was sick of dumping it into 1st gear every time I pulled it back to 2nd to go down a steep hill. Instead of just pulling the shifter back into 1'st gear like you do with the stock shifter, you bang it back, then it returns to it's original position. You do that once for each gear. Once you're in first, you just bang it forward to shift into second, then bang it again for the next gear, etc. If you're the type of guy that just puts it into "D" and forgets about it, you'll find no functional advantage to buying it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old 10-17-2000, 12:25 PM
FiReBReTHa's Avatar
AAAh... im startin to understand it,
i learned that if you manualy change gears (all the time) it will destroy your tranny, so then i thought for some strange thing this would avoid that. i still like the shifter, but have no use for until i think i get what is called a 'shift kit' ?
that will change your valve body, has anyone had experiance with this? like doing it yourself, or how much on average does it cost to get installed,
Thanx
Old 10-17-2000, 01:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't know how much it is to have installed, but it's easy to install yourself. Visit the "Transmissions & Drivetrain" message area, there's quite a few messages about shift kits. In fact I wrote up a huge list of hints in one of them- just go to the transmission forum, click on search, type in "shift kit snap ring", and click on search again.
Oh the B&M lists the shift pattern as 1, 2, 3, D, N, R, P. D becomes 3, and OD becomes D, as it should be.
You don't 'need' a shift kit to use the Megashifter.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old 01-03-2002, 02:57 PM
89camaroRSV6's Avatar
can u just use the mega shifter like a ordinary drive mode ... simply by pushing it into drive and forgettin about it... or do i have to manually go from 1 to 4 all the time..
whats a forward and reverse valve bodies...
Old 01-03-2002, 03:15 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
It works just like your stock shifter with the exception that it only moves "up" one gear at a time. This way you can pull it down into first when you're racing (or something) hold it in first 'till it's time and put your weight into moving it to second. On your stock shifter it would slide up all the way to neutral (unless your careful). Other than that, it works just like stock. So yes, you can just leave it in drive.
Old 01-03-2002, 03:31 PM
oh yeah good to see that someone responds to a thread thats almost 1 1/2 years old
thanx ...
and what do u think of the B&M shift kit
would it kill my tranny or does it improve life
Old 01-03-2002, 03:48 PM
Mark305TBI's Avatar
Wow...I didn't even look at the date that it was originally posted.
Don't know anything about shift kits...sorry.
Old 01-04-2002, 12:04 AM
FiReBReTHa's Avatar
smoother harder shifts,
Old 01-04-2002, 12:44 AM
Jza
Jza's Avatar
Depending on the kit, I wouldn't say "smoother"..
[nevermind on this second part]
Old 01-04-2002, 11:29 PM
Rizock2000's Avatar
Is it really that bad for the tranny to powershift from 1,2,D,to OD? I had my tranny rebuilt just a couple of months ago, but I powershift just about any time I come to a stop light. Am I going to blow my tranny again doing this?
Old 01-05-2002, 12:19 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I upshift but I dont downshift.
Old 01-06-2002, 12:07 AM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
As far as hurting the tranny goes...the tranny doesn't know whether it's the computer or the driver that's doing the shifting. It's just that if YOU are shifting, it's probably more aggressive driving, at higher RPMs. Therefore it is probably gonna wear out the tranny faster, but no, it's not actually the shifting that's doing it.
As for the reverse valve body is concerned, I think it allows you to shift in a reverse pattern. So if you were drag racing, you'd pull BACK from 1 into 2, then BACK into 3....etc. instead of pushing it up the pattern.
I do have a B&M MS question ... can't you operate it exactly like a stock shifter, using the trigger to downshift, and just being careful when you shift from 1,2,3 etc.? Then if you WANT to ratchet shift, I thought you had to push DOWN on the t handle when in nuetral or something? I dunno?
Old 11-12-2007, 08:22 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Re: Hmmm... Not understanding this B&M shifter.......
ypu.
Old 11-12-2007, 09:11 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Originally Posted by 84RIceEater
ypu.
lol... uh this thread is 5 years old. It was actually originally started in 2000!
Old 12-26-2007, 01:44 AM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
wouldn't that make it 7 years old??
Old 01-05-2008, 05:28 AM
Kenneth'sbirdie's Avatar
Car: 1987 firebird
Engine: carb'd 350 (******* swap)
Axle/Gears: sure aint positrac
nope now its 8
UltRoadWarrior9
04-28-2020 10:39 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
roysatikas
09-22-2015 08:15 PM
MarineIROC
Southern California Area
09-16-2015 05:40 PM
armybyrd
09-16-2015 07:00 AM
Quick Reply: Hmmm... Not understanding this B&M shifter.......
