Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Opinions for Engine Mounts
Old Oct 29, 2003 | 07:15 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Right board?--->I'm going to replace my motor mounts, among other parts, but I was wondering what is out there and what would be best. Got the 305 TBI in there now, but might swap to TPI or 350 w/ TPI in the future. Either displacement would be a small block, would that matter in mount selection? Prolly won't ever get above 300 hp... feel free to drop in your $0.02. Thanks-Efrain.
Old Nov 2, 2003 | 11:05 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Any one? Anything.
Old Nov 2, 2003 | 11:37 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
You could go with stock style from NAPA, "clamshell" or a lot of people go with poly mounts from here for example: http://www.spohn.net/product.cfm?productid=1363 good luck
Old Nov 3, 2003 | 10:01 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
i bought energy suspension motor mounts. u have to drill out the rivits in the clam shell to put em in. i think they look cool. they are polyurethan so they will last. the motor has very little movement now, i am happy with them.
Old Nov 4, 2003 | 12:57 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just set the motor donw in there and then wrap some tow chain around the block 2-3 times and weld it down. Just pray for no valve cover leaks.
Matt
Old Nov 4, 2003 | 02:56 AM
MdFormula350's Avatar
sounds like homemade solid engine mounts works for me
Old Nov 4, 2003 | 10:26 AM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
do the prothane engine mounts work the same way as the ES? where you have to use your old clamshells?
thanx
zed
Old Nov 4, 2003 | 09:22 PM
25THRSS's Avatar
thanx
zed
yes, IMP, prothane is better quality also.
Old Nov 5, 2003 | 12:56 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Elaborate please.
Still catching up to the board lingo. IMP=? What makes the prothane better? Thanks, Efrain.
Old Nov 5, 2003 | 01:45 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
I would stick with the factory mounts. The only reason being they work just fine for the least amount of money. I reused the mounts from my LG4 when I swapped it out for a 408 SBC. With 110K miles on them, they were/are still in fine working order. Also, I've seen claims that some aftermarket mounts change the height of the engine, sometimes causing clearance problems when you go to install long tube headers.
Old Nov 5, 2003 | 03:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i used energy suspension mounts and they raised my motor.....
oh yea long tube headers were an 8 hour session of grinding on the crossmember to get them to fit. Now i have to weld in plates on the crossmember to plate it up for strength.
but the motor doesn't move much now.
Old Nov 5, 2003 | 07:14 PM
25THRSS's Avatar
Re: Elaborate please.
oops, meant to put IMO, or in my opinion. They fit better than energy suspension from what I can tell others have said. Energy suspension seems to cause some added vibrations with their tranny mount and their motor mounts seem to raise the engine way too much over stock. Also, with suspension parts, the prothane won't squeek as much.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
