Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
power
Old Nov 6, 2001 | 08:50 AM
86Street's Avatar
power
how much horsepower would a rebuilt 327 with headers and straight pipes...whith a 750cfm carb and a weiand intake
Old Nov 6, 2001 | 08:12 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Chevy put out two good 327's in the 60's. One 300hp and one 350hp. The 300hp one had the same cam as my 283 in my Chevelle. It only had .390"int and .410"exh lift. The one w/350hp had a slightly larger cam .447"int/exh lift. It also had 11:1 compression. I'm not sure about the compression ratio on the 300hp engine. I think it was either the same or 10:1. Regardless with about 10:1 compression, good carb jetting, and even a mild street cam you should be able to get to the 325-375hp range (at the flywheel). I love the 327ci motor, one of the best ones if you ask me. Let me know how it goes for you because I've been contemplating a mild 327 w/TPI on my 86 IROC. Hope this helps,
Jason
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns, Throttle body airfoil.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
