Quality of coating on SLP headers?
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Im going to switch out my older Edelbrock headers with some newer SLP 1 3/4 headers. I will get them coated for longevity etc. What is the quality of the coating(shine, lustre) on the headers direct from SLP? Any comments?
Car: '88 Iroc
Axle/Gears: 3.45
Hi Jeff,
The only thing I'd be concerned about with respect to factory coated headers is having to clean up obstructions prior to installation. I don't know about the SLP's, but my Edelbrock's had nearly 1/4" of the A.I.R. tubes sticking down into each header. I ground them all flush and that area of the coating would have been compromised if my headers were precoated. Not sure if this is a big deal or not, but it would have bothered me. The other thing is, I'm going to have an extra bung welded in for wideband O2. Once everything is done, and I'm satisfied, then they'll get their ceramic coating and I'll have my piece of mind.
Btw, how's life treating you in Oregon? Did you ever get your car to a track for that dip into the 11's?
--Aaron
--Aaron
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
slp's are stainless... don't see why you want to coat them
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Actually they are stainless steel. At least that's what SLP says.
This is directly from there website:
Are crafted from mandrel bent .055" wall thickness 409 stainless steel tubing for smooth uninterrupted exhaust flow.
Have 3/8" thick, investment cast 304 stainless steel flanges for better sealing and long life.
Anyways, as formularpm said, it is for thermal management.
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
http://www.slponline.com/view_produc...TNUMBER=30001C
you get things coated so they will keep the heat in the exhuast not in your engine compartment.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
if i remember correctly, there are different grades of stainless, to which some will allow for magnets to stick (lower grade stainles...)
i dont rmemeber how it goes, maybe someone else can shed light on that...
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
