Spohn LCA Relocation Brackets
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Installed my set yesterday. Very easy and straightforward! Only needed help from my buddy with some welding. Lemme tell you, what little spin I had off the line is now virtually gone.....these little buggers work wonders!
Pro: much better acceleration from a stop
Con: Little bit rougher ride, but that is definitely to be expected!
Car: 89 formula 350
that picture doesnt show the welds, or the rust-stopping enamel paint
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
There was a guy in another thread about LCA brackets who said they didn't help, actually he said on intial launch they helped, but after that the car wouldn't sit down and you'd need really sticky tires to really benefit it. I think that was the first time I had heard anyone say they dind't like them. Any other opinons.
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i wanna install mine, but i don't have a welder so i gotta wait a few months till i save up cash, cause i have other bills to pay 1st. but i'm sure i'll love em.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I know Im in the minority here, but they made no difference at all in my times. Ive argued with many members about this issue, I seem to be the only one who regrets buying them.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The whole point is to keep the rear of the car from sitting down or "squating". When the rear of the car squats the angle of the LCAS has the rear end lifting up off the ground causing more wheel spin.
If you install them, make sure you drive on one bolt hole around the block then look at the angle. If the angle from the rearend to the frame is pointing up, you're golden.
If it's pointing downward "Rearend higher than frame mount" then you need to go on the next bolt hole down. If you were already on the bottom bold. You need to replace your rear springs :O)
I'm on my bottom bolt and just barely got the angle right. Me need some new springs.
BTW It made a huge difference in traction to the point that the car feels slower cause I don't spin all the time with my 3000RPM stall! Woot! Time to get better than a 2.0 60ft
Engine: 406 Roller
Very nice car.
Jason
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
your car is awesome, i love the pic in your sig. I really like the Y2K rims on it, I want to see those rims on a T/A, preferably a white T/A
Engine: peanut LB9
Thanks man, the rims are ROHs, though. Now if only the car was running!
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
