Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Pics of the Mini Ram installed
Old Oct 23, 2000 | 07:01 PM
ZBRA's Avatar
Car: 1972 Corvette
http://firehawk.cmcmfg.com/~east/ste...d/DSC00001.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00002.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00003.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00004.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00005.JPG
Here are some pics of both of my cars.
http://firehawk.cmcmfg.com/~east/ste...d/DSC00006.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00007.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00010.JPG
http://firehawk.cmcmfg.com/~east/ste...d/DSC00012.JPG
Enjoy, and let me know what you think.
I'll have dyno numbers for the Mini Ram Vs. the old Super Ram soon.
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 RWHP 374.9 RWTQ
Old Oct 23, 2000 | 09:33 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Steve, man, that is one fat shot of NOS you'r running. How big a shot is that?
Is that an LT1 top end?
Looks great
25th Anniversary Z28
Old Oct 23, 2000 | 09:51 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
That is one nice looking car. Are those ROH wheels and if so what model are they? I also agree with GOFASTER that is one nice looking NOS setup. Man that car must haul major a$$.
Old Oct 23, 2000 | 10:29 PM
ZBRA's Avatar
Car: 1972 Corvette
You guy will feel better knowing that you are not the first to mistake that for NOS.
Those are real -6 braided fuel lines.
Here are some pics of the back of the intake and how I have the fuel lines run:
http://home.webworks2000.net/guido/zbra2.jpg
http://home.webworks2000.net/guido/zbra3.jpg
Nope. It's a mini ram painted red.
Nope. Those are 17" X 9" '98 Z28 SS wheels from SLP.
Old Oct 23, 2000 | 10:46 PM
GhoSSt's Avatar
How much did the TPIS miniram end up costing you all things considered?
Kelly 'GhoSSt' Rosato
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
Old Oct 23, 2000 | 11:23 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Z, what does that sticker say on your air intake near the K&N sticker??
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Oct 24, 2000 | 07:24 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Links are not working for me.....
Is it on my end or your end????
Would like to see the intake setup since I am going to be buying the miniram soon...
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
http://members.aol.com/jwnolte/raven.htm
Old Oct 24, 2000 | 10:01 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey Steve, those are some great pictures dude. I bet that your car now operates like a different animal. Did you mask and spray paint the manifold, or did you powdercoat it?
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Oct 24, 2000 | 09:16 PM
ZBRA's Avatar
Car: 1972 Corvette
That is a factory sticker. I think it's something about the A/C system if I remember correctly.
I paid $800 for the mini ram with rails.
$170 for the AN fittings and hose.
$15 for cable brackets from TPIS that didn't work, and I didn't use
$15 for a generic cable bracket that I modified to work.
$10 for the water neck. (not from TPIS)
about $90 for misc things like bolts, paint, tape, hoses, paint thinner, dremel discs, JB weld, etc. etc.
So, about $1100.
If you are wondering about the JB weld, the intake was used in a marine application and had holes drilled into the water jackets in all four corners. It was also overported for my heads. I had to build the walls back up inside and then port match it to my heads.
Mask and spray paint.
Old Oct 24, 2000 | 10:43 PM
98camaross's Avatar
hey z that looks nice! is a Minni Ram beter than an Accel Super Ram . what the difference in two , which one is beter?
Old Oct 25, 2000 | 02:29 PM
Dan87IROC-Z's Avatar
That is one of the most beautiful Camaros I have ever seen. Abostlutley awesome!!!!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 25, 2000 | 02:51 PM
jRaskell's Avatar
The mini-ram provides more top end potential at the expense of bottom end grunt. Super ram is a bit more of a compromise. Doesn't provide as much top end potential, but also doesn't sacrifice bottom end grunt. Super ram uses longer intake runners then the mini-ram that are larger then stock runners, but also a bit shorter. The stock runners provide higher velocity airflow at low rpms which is desirable for power, but they are restrictive at high rpms. Larger runners provide the necessary flow at higher rpms, but provide lower velocity airflow at low rpms. Runner length also plays into the equation, but I'm not so clear on just how. Shorter runners are better for high rpm power, longer runners for low rpm power. I know shorter runners are more susceptible to combustion pulses from each cyclinder affecting flow into adjacent runners, but that gets into your cam setup and timing and more complications.
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
