Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
What SFC's does everyone have?
Old Nov 19, 2001 | 10:35 PM
Raptor Pilot's Avatar
I am looking to get a set, but I want to hear what you guys have, what fits best, etc. I have heard that some don't fit that well with the dual cats sometimes. I don't kow how much truth there is to that, but I am curious. I want to avoid any stress cracks in the roof pillar area, epecially since I am getting paint job in the spring.
Old Nov 19, 2001 | 11:46 PM
BORLAZ06's Avatar
spohn here, i think they're great.
1992 Camaro Z28
Stock
5 Spd
Old Nov 19, 2001 | 11:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Alston's fit great with dual cats. Search the Chassis/Suspenion/Brakes board for more info, this topic comes up all the time.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 20, 2001 | 06:39 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I've put in a few, the Jegsters are the best so far as long as you get the bolt in version, bolt them in, then weld them in.
Old Nov 20, 2001 | 07:56 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Alston's here.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Nov 20, 2001 | 08:14 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
SouthSide Machine SFC's are the best. These, along with the Spohn and Global West SFC's are the only ones that get welded along the rocker panel to further stiffen the body and not just connect the front and rear sub-frames. Being made out of rectangular tubing also makes them great jacking points.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 20, 2001 | 08:51 AM
craiger's Avatar
Greg,
Do you have dual cat's? I am looking at getting the SSM's or the Spoohn's. Not sure how the SSM's fit with dual cats??? Any help would be greatly appricaited.
Old Nov 20, 2001 | 09:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Alston's here. One of only two so far that will fit a 'vert.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 20, 2001 | 10:22 AM
Engine: 385 HSR
Nope, I don't have dual cats, but I know somebody with a '91 Formula 350 with dual cats that does have the SSM SFC's. The Spohn's will only half-fit. The long pieces that run along the rocker panels will fit, but the right-side brace going from the SFC to the tranny tunnel probably won't fit, sometimes even on single-cat cars. That's about the only difference, except that the Spohn SFC's are powdercoated and the SSM's are bare (paint to match your car if you want).
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 20, 2001 | 12:22 PM
formul8!!'s Avatar
Car: 2004 GTO
Spohn has two versions: single cat and dual cat. The dual cat version has the piece for the rail to the trans tunnel not attached to be able to weld it in to clear the cats.
Also, powder coating is extra $$.
Old Nov 20, 2001 | 01:55 PM
craiger's Avatar
So will the SSM's fit with my dual cats? If not, what must be done?
Old Nov 20, 2001 | 10:30 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
I have spohn's. mine are a tubular fit however probably a bit diffenten that what most of you have, they have solidified my Z substantially.
Old Nov 21, 2001 | 01:17 PM
formul8!!'s Avatar
Car: 2004 GTO
<font face="Verdana, Arial" size="2">Originally posted by craiger:
So will the SSM's fit with my dual cats? If not, what must be done?</font>
The AIR tubes to the converters may have to be relocated and rewelded. They may also have to notch the SFC.
Old Nov 22, 2001 | 10:37 PM
Z28Express
Guest
Posts: n/a
The SSM will NOT work with dual cats, not even close, I know from experience.
Get the Spohn dual cat version, they fit perfectly on my car and made a night and day difference, I'm VERY happy with them!
Old Nov 23, 2001 | 09:33 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Spohn's fit awesome, I have them on my car.
Just my opinion though.
Old Nov 23, 2001 | 10:54 AM
TPI_Guru's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GregWestphal:
</font>
The kenny brown super subframes also weld along the pinch paneling underneath the rocker panels and make it a "full frame". They are also made of tubular steel which i feel is stronger
Old Nov 23, 2001 | 12:08 PM
pontiac's Avatar
DIY ones here. fits perfectly and up to 20% stronger than brand X
-P
Old Nov 24, 2001 | 02:05 PM
Formula9's Avatar
SSM SFCs fit with dual-cats without modification.
Old Nov 24, 2001 | 08:43 PM
Z28Express
Guest
Posts: n/a
Formula9 I have factory dual cats and the SSM weren't even close to fitting, I sent them back to Summit.
Maybe you have an aftermarket dual cat y-pipe but the stock one no way will they fit.
Old Nov 26, 2001 | 12:17 PM
formul8!!'s Avatar
Car: 2004 GTO
<font face="Verdana, Arial" size="2">Originally posted by Formula9:
SSM SFCs fit with dual-cats without modification. </font>
A friend of mine had them put on a '91 Formula 350 and a '92 Z28 5.7L both with dual cats and the exhuast had to be modded both times.
Old Nov 26, 2001 | 01:19 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
i'm going to use southside sfc
i'm not going to run any cats.
1986 Iroc 305 small block chevy: ported heads, 1 3/4 slp headers, rpm intake(ported), 1.6 roller rockers, performance valvejob, titanium retainers, compcams conical valvesprings looking for cam.
Old Nov 26, 2001 | 05:53 PM
JPrevost's Avatar
Car: 91 Red Sled
Alston's here too. Got them on a group purchase a few years ago. Everyone has been having problems with the bolt holes getting loose but I have yet to feel any play in either of mine. I'll weld them this spring when I have to install my LCA relocation brackets and weld the axle tubes to the carrier housing. It's all good though. Any SFC is better than none.
Old Dec 1, 2001 | 05:12 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Kenny Browns here, Changed the whole feel of the car. Nice and tight now.
Old Dec 2, 2001 | 07:22 AM
ede's Avatar
ede
made my own, way better and way cheaper than any you can buy, but a bit heavier than most.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Dec 6, 2001 | 10:20 PM
wiesman's Avatar
I agree with Greg Westphal. The SSM and others that are welded along the rocker panel are much better. I have SSM, they didn't fit my SLP y-pipe and single cat. I had to cut out and reweld a small piece but after that they fit fine.
Old Dec 10, 2001 | 08:53 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
I have a brand new set of SSM Lift bars complete with non fitting SFCs that interfere with my dual cats(92 Z28 L98). It required modifying the cat or the SFC and neither I was willing to do, went with Alston SFCs and had no problems what so ever. Anyone want a complete SSM Lift Bar Kit for a good price?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Apr 28, 2001 05:02 AM
