trans pan
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I've had one since I had the trans built 3 years ago. So far, so good. I don't have a trans temp guage, so I can't tell for sure if it keeps it cooler or not, but it's not hurting anything.
Good fit & finish, mine had nice, clean welds around all the 'cooler' tubes, and whatever finish they put on it is still pretty shiny.
As far as ground clearance, it doesn't really hang down much, not as low as the crossmember, so i've never bottomed it out. (And I have put some dents in my stock engine oil pan)
Plus, it's pretty cool to look at when you're under there.
I run the Derale pan. It has the fins but the best feature is the added capacity, it hold two full qts extra than a stock pan. It cuts down on ground clearance though. However I dont care BC my Hooker SuperComp longtubes hang lower, so I gotta baby it anyway.
As for an actuall cooling gain, I think that would be hard to measure. Not a big concern for me though as I also have a huge B&M Supercooler also, 28,000GVW.
Overall the fit and finish is excellent, heavy gauge steel, drain plug, etc...
Car: 1992 B4C 1LE
when I worked at Aamco we were forever having to swap ot those tube vented pans due to leaks around the tubes.
Looking at the welds in my pan I dont see them ever leaking at any time in the future. We are talking a serious bead here.
Plus the fact that it is installed and doesnt leak now.
Car: 1992 B4C 1LE
now that I think of it, might have beenan old trans dapt pan or something. It was thin metal
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
