Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Fitting an Lt4 cam into my "gen 1" roller block..
Old Sep 12, 2004 | 04:53 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
well i just discovered that my Lt4 cam will not allow a conventional rollar sprocket to bolt up to it so Im guessing I will need a GM lt4 cam sprocket and chain..
will I have issues fitting these parts onto my older block??
Old Sep 12, 2004 | 06:16 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Why won't it fit up? I just put a "LT1" cam into 355. They are the same camshaft really. No differences. I did have to cut part of the "stick" coming out the front of the cam that turns the timing gear. But the only reason I had to cut it was b/c it was too long and the timing cover wouldn't fit all the way on.
So no you don't have to run a LT4 timing set.
Old Sep 14, 2004 | 12:39 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
If I remember right when I installed my LT4 Hot cam I just tapped on that "stick" with a hammer until it matched the old cam. And like Chris I then used a standard gen 1 timing setup.
HTH
Old Sep 14, 2004 | 07:12 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I tapped it in as far as it could go, and then cut it b/c it was still WAY too long.
That cam should work perfectly, w/ a standard timing set. Its the same cam physically as any GEN 1 hydro-roller cam...
Old Sep 14, 2004 | 05:16 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
hmm thats odd.. I bought a generic GM hyd rollar timing set upon installing the sprockets I discovered that the cam bolt holes do not match the bolt holes in the sprocket. the cam is smaller.
I looked through the GMPP catalog and it shows timing sets for LT4 as well as the normal hyd rollar and hyd timing sets.
Old Sep 15, 2004 | 12:07 AM
IROCFAST's Avatar
If the cam bolt holes are a smaller circle, then they sent you a roller chain for a flat tappet cam. The dia. is smaller to allow the use of the cam retainer. All you have to do to install the LT series cam is to tap the alignment dowel in.
Old Sep 18, 2004 | 03:20 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
thanks for the reply, i went back and verified that the part was indeed for a hyd rollar cam and yet the holes do not line up plus the sprocket will come in contact with the cam retainer bolts... anyone have a part number for their chain and sprocket set thats worked for them?
Old Sep 18, 2004 | 06:16 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Summit True Roller is SUM-G6601 $41.95
Sealed Power CTS1006 $35.89 @ Rockauto
IIRC, the GenII cam dowels are .65, and standard SBC are .3, so you need to push it about half way in
Old Oct 2, 2004 | 02:32 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
well... a normal timing set definatly does not work
so i bought a crowel timing set for an LT1 and it fits up with the bolts holes however the cam gear sits awful close to the engine block, nearly touching the cam button retaining bolts and it does actually slide on the cam retainer. don't those LT1's have a waterpump gear that goes between the cam and the sprocket?
I'm guessing im going to have to at least get that gear to keep the sprocket away from the retainer wont I...
has no one else had these issues with their LT4 cams?
Old Oct 3, 2004 | 10:06 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Mine went in without any problems. I bought the block with a Crane cam in it for a Gen 1 roller. I just swapped the dowls from that cam into the Hot Cam and bolted up the same timing set.
Old Oct 5, 2004 | 04:59 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Can anyone post pics of what has to be done? I'm buying an LT1 cam for my GTA and would like to know what to do to make it fit . THanks guys!
Old Oct 5, 2004 | 05:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Here this should help. Here is an LT4 cam that I was going to use in my '90 TBI car. You only need to shorten the dowel pin down to 5/16" or so when using a Gen II cam in a Gen I roller motor.
Gen II LT4 cam
Old Oct 5, 2004 | 05:54 PM
Car: 1991 GTA
Thanks for the help. I really appreciate it !
junkcltr
Aug 2, 2019 11:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
