Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Catco!
Old Nov 7, 2004 | 09:18 AM
TransAmman87's Avatar
Car: 90 Trans Am
Catco!
I just wanted to let everyone know who needs a new catalytic converter to go for the CATCO brand. I got mine put on the other day and let me tell you, my car is alot louder and the idle is much more smooth. Granted my old converter was shot to ****, so there was noticable difference, but as soon as i started up my car there was a smile across my face. Anyway, the reason I say go CATCO direct-fit, is because it didn't cost me an arm and a leg to get a freer flowing cat. I am very pleased with this product and recommend it to all.
Old Nov 7, 2004 | 11:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I agree, a Direct fit Catco Cat is the way to go and the price is OK also.
Old Nov 8, 2004 | 07:01 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Another thumbs up here. I put on a direct fit Catco from Summit when I did my full exhuast. Two things happened. One, I probably picked up a couple extra horse over the old and rusted cat. Two, I passed emissions cleaner than stock.
Old Nov 8, 2004 | 02:18 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
can you guys give me a part #? i have an 88 GTA 305
Old Nov 8, 2004 | 03:16 PM
Cliff92Z's Avatar
Car: 1992 Z28
Do you know if they make one without A.I.R line?
Old Nov 8, 2004 | 04:11 PM
DJP87Z28's Avatar
I think they all come with AIR line...
Old Nov 8, 2004 | 04:15 PM
DJP87Z28's Avatar
P/N for the 3" in & out is CTO-9118. Just check to be sure for your application.
Old Nov 8, 2004 | 05:20 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i have had a 3 inch catco for 2 yrs now , and i highly recommend then to everyone as well.
Old Nov 9, 2004 | 07:57 PM
Car: 90 Trans Am
Yeah, its been a couple days since I had it put on and I've noticed better excelleration and better idle. A little old lady on my street thought I was going fast when I went passed her because the exhaust note is so much louder and she was all "Slow down jackass"... I just smiled and waved ( I was only gong 15mph) . Anyway, its great to hear that everyone likes this CAT too. Its good stuff.
Old Nov 11, 2004 | 11:00 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Well, here's one vote against. I had to have the heat shield rewelded twice and then the catalyst brick inside broke up into pieces requiring a replacement, all within 2 years. I now have a Random Technologies cat with no problems after 3 years.
Old Nov 12, 2004 | 12:28 AM
LPE383's Avatar
Car: 84 Z28
Engine: 350 L98 from 89 vette
Transmission: World Class T5
Axle/Gears: 3.70 Precision Gears
I got a 3" pipe from www.testpipe.com
They gave me a hard time at first because they said it was for "off road use only" but I convinced them to send it to me. Can't get any freer then that! I got that pipe and dynomax cat back and love the sound. I had flowmaster,hooker and they don't compare.
Old Nov 15, 2004 | 11:54 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I put on a catco dual SS setup I bought from Jegs or Summit. Actually my local muffer shop put it on. They had to modify it a little even though it was a direct fit for a dual cat car. It cost me $100 for them to put it on, not too bad. Anyway, no problems so far, except there is a vibration and noise at a certain speed when decellerating. I think this is because they didn't reattach the center support from above. Its like the whole thing resonates for a secton and goes bllllllllllaeaaa.
Old Nov 25, 2004 | 01:44 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You have to take what you get with a grain of salt on here. 20 people love catco, on their stock motor. yay!
If you have something modified like you and I, carsound, magnaflow is the only way to go.
-- Joe
Old Dec 3, 2004 | 03:01 AM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
well i liked the catco, atleast for emissions testing anyways. Helped my engine pass the visual and emissions tests. Day after the test I took it back off and punched it completely out. They aren't expensive and not very hard to take in and out unless you weld them in. I will just buy another as a spare to use for testing every other year.
Old Dec 3, 2004 | 06:23 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why did you punch it out?
-- Joe
Old Dec 5, 2004 | 02:21 PM
CashMunson's Avatar
Engine: 408 LS
-- Joe
so it's hollow, no restriction at all. And where I live it's illegal to have no cat converter, you must have one on your car. So if I get pulled over it's down there if they check, it just happens to be hollow which they won't know.
Old Dec 6, 2004 | 07:12 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I hear alot of good things about them but I think I will go with CarSound when it's time to order.
Old Dec 6, 2004 | 09:33 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm trying to figure out why buy a cheap cat, punch it out, then buy another cheap cat to get sniffed, when you could have just bought a decent carsound cat and not punched it out.. ??
ChevyKen
Dec 18, 2001 05:38 PM
ChevyKen
Dec 14, 2001 03:00 AM
MetKiss316
Dec 12, 2001 07:21 PM
MetKiss316
Dec 10, 2001 07:42 PM
MetKiss316
Dec 5, 2001 03:01 PM
