Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD inline fuel pump
Old Jan 20, 2005 | 05:49 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Has anyone tried this inline pump?
Its at www.summitracing.com with part number MSD-2225.
It says up to 80PSI and 43 GPH, I am just thinking about using it for a Carb to TPI swap (Because it is crazy cheap), but I would like to hear some feed back on the pump, or pumps in general.
(I dont want to hear keep the carb over TPI either, this is not what the post is about.)
Old Jan 20, 2005 | 05:51 PM
Joe_L's Avatar
Car: 1995 Z28
Opps... forgot the picture
Old Jan 21, 2005 | 06:11 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yea thats the one that i am running in my riide. it works and its pretty nice
Old Jan 21, 2005 | 07:06 PM
89_IROC_98U's Avatar
Forgive my lack of knowledge, but would this allow me to eliminate my in-tank fuel pump? That would rock - I've already spent $500 on one pump replacement, and I'd rather not go through that again.
- 89_IROC
Old Jan 21, 2005 | 08:00 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
A theoretical question ;
If I put this pump on a stock vehicle would It decrease its mpg or would the mpg be same?
Old Jan 21, 2005 | 08:18 PM
This is nothing more than a guess, but it seems to me that the fuel pump itself does nothing more than pump fuel and would therefore have a negligible effect on fuel economy.
Someone correct me if I'm wrong - this is an interesting question.
- 89_IROC
Old Jan 22, 2005 | 04:19 AM
smokefan's Avatar
it would remain the same as far as your mpg goes and yes you can use this pump in the place of the stock pump in the tank like i did. make it a lot easier when it come to changing it.
Old Jan 22, 2005 | 12:44 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Hey Smokefan
What do you do with the in tank fuel pump if you installed the msd inline pump? Do you have to take the one out of the tank and install a catch or can you just install the inline and don't worry about the intank pump? Forgive me if its a stupid question but I really don't know.
Old Jan 22, 2005 | 04:18 PM
smokefan - Thanks for the response! Good info there.
lilbowilson - Thanks for that question...I hadn't thought of that, and now I'm curious too.
- 89_IROC
Old Jan 23, 2005 | 12:36 AM
smokefan's Avatar
the pump will pull throught the stock pump so there is no need to remove it. you wont have a problem with the pressure with the msd pump either.
Old Jan 23, 2005 | 01:22 AM
Car: 87 IROC
THANKS for the info I'm going to get one.
Old Jan 23, 2005 | 05:33 AM
smokefan's Avatar
how do you like the stealth ram
Old Jan 23, 2005 | 10:16 AM
Joe_L's Avatar
Car: 1995 Z28
Thanks for all the replies guys, I think I will order this pump sometime next week.
Just two more quick questions; because it is an 80PSI pump, can the fuel pressure regulator on the fuel rail for the TPI hold it at its steady 44 PSI(or whatever it is), or should I also get a AFPR?
Oh, and does it matter that it is 5/16 input, 3/8 output? I am assuming it flows more gph then the stock pump anyway so it shouldn't matter.
Old Jan 23, 2005 | 10:33 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Some people have problems with hooking a inline pump up and keeping the stock pump in the tank, the stock pump will sometimes act as a restriction, you will just have to try and see how it works. I would NEVER NEVER run a inline pump because all the ones I've heard make a LOT of noise.
Old Jan 23, 2005 | 11:58 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
all you need is a good intank pump like walbro 255.
Old Feb 3, 2005 | 05:48 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
That is the pump I've been running for 2 years now without a problem in my TPI equiped ElCamino. It is a little on the loud side but I got used to it after a few weeks, mounting it on rubber pedastals helped a little. For me the stock regulator has been working great. I am going to get an intake pump and sender when I can find one on the cheap side.
Old Feb 5, 2005 | 01:56 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I'm running that pump with my recent EFI conversion as well. So far I've been quite pleased with it. My car was originally carbeurated so I'm just pulling through the factory in-tank filter sock (that I'm assuming is still there lol) and then I plumbed in a factory 3rd gen EFI fuel filter so it's an easy swap out part if/ when I need it. The pump is a little loud as eric305tpi said, but it's quite livable. It's funny actually, I helped my friend with a tpi conversion on his '87 El Camino and he went with an in-tank pump and if our cars are running side by side and you're standing behind them, you can hear my exhaust (American Thunder) and his fuel pump. If they're shut off though his fuel pump is quieter than mine. Just a funny tidbit. Anyway, with that said, yeah that pump seems to be a good deal, and I've been happy with it so far! Here's a pic of my install:
-Paul
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
