Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Comp cams Solid roller cam & Hi-tech lifter
Old Apr 23, 2006 | 12:06 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
The Hi-tech lifter are not suposed to be used for sustained idle cause the main oiling is crank oil splaching on it...I alredy got the Hi-tech one So i check the endurex ones with a groove on it that are moore situable for sustained idle with the idea of making my own groove.With further examination of the Hi-tech i found that they got a presurised oil passage to the axle berings so the should be ok !? Do someone have experience with thoses ?The cam is not billet its more a cast core do i need a bronze gear or the melonize one is ok? Is the stock fuel pump push rod is ok to use?
Old Apr 23, 2006 | 01:02 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
That track in the video in your sig, is that Luskville? Are you in Gatineau/Aylmer/Hull region? If so check out the Ontario region on here. Also check out Ottawafbody club in Ottawa. Hylton will hook you up to the club if you want.
Old Apr 23, 2006 | 06:34 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Yes your are right Luskville dragway
Old Apr 24, 2006 | 12:04 PM
Shagwell's Avatar
Car: projects.......
does it oil the lifter axle or just push oil up the pushrod???
Old Apr 24, 2006 | 10:47 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
The axle ...for the pushrod theres a other hole on the side.
Old Apr 25, 2006 | 08:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't look like a tiny little hole like that would take long to get plugged by deposits in street use.
Old Apr 25, 2006 | 08:45 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I have those same lifters in my new motor with a XR280R. I haven't ran it on the street yet, but I did test fire it once. It saw plenty of oil to the valve covers (75 PSI and stock volume). I was told by CompCams it would be fine in street use as long as I didn't sit at 2k RPMs for more than 2 or 3 minutes at one time. They told me just to rev it to 3k+ once and awhile and it would lube the camshaft and lifters again.
I think compcams offers a tool to scribe/cut a oil line in the lifter bores to get more oil, but I haven't researched anything past that since my combo was already about 75% assembled by the time I found out.
Old Apr 25, 2006 | 09:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
P/N 5003 for standard chevy lifter bore.
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
