Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
GMPP
Old Aug 17, 2006 | 07:39 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
GMPP
I have this cam in my 355 which hasn't been put in my car yet and I was wondering if it's going to add any power at all or if it's just an average stock cam?
Chevy IROC-Z, 206/216 Duration @ 0.050, Hydraulic Roller Camshaft :: 14093643 - SDPC
Old Aug 17, 2006 | 07:49 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Give us more details.Is this a TPI motor or carb?If carb what size and intake.Do you have headers?What is the cam in it now.More info please.
Old Aug 17, 2006 | 07:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
stock smallish cam
Old Aug 17, 2006 | 07:53 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
1989 l98 block and heads, TBI, stock intake and TB (for now).
I
Old Aug 17, 2006 | 07:56 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
1989 l98 block and iron heads, TBI, stock intake and TB (for now).
I was just wondering if this cam will make anymore power than the cam that came in the tpi l98 setup. Also dose anyone have any idea what getting rid of the runners and going with the TB setup will do for horsepower? the stock l98 had like 230...I was just trying to get an estimate of what it will do for me. It's probably the same cam that came in it originally.
Old Aug 17, 2006 | 07:58 PM
zz4monte's Avatar
TBI.Are you sure you don't mean TPI. Tune Port Injection?
Old Aug 17, 2006 | 08:01 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
No I mean TBI. We had the block and heads from the l98 but didn't have any of the wiring and the injectors for the tpi were bad. We're using tbi.
Old Aug 17, 2006 | 08:06 PM
zz4monte's Avatar
Well if it was tpi I would say go for a zz4 cam 208 221 474 510 112 lobe seperation but I don't know what the limit of TBI is.That cam is stock and I think it has a 115 lobe seperation but I am sure someone will correct me.This should be transfered to the TBI board.
Old Aug 19, 2006 | 05:23 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
How far do you plan on going with the TBI? The cam you listed is pretty small, but not too bad of choice if you plan on keeping the stock TBI and intake. If you plan on swapping on an intake and modding your TBI (or even going w/ a larger unit), then you are wasting your time with that cam.
midge54
Dec 27, 2019 04:14 PM
RedLeader289
May 28, 2019 01:47 PM
midge54
Jan 29, 2017 07:00 PM
kwikgta
Mar 15, 2001 11:15 AM
