Hedman headers
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have not used that header but I did a ton or research when I went to purchase headers for my car. The two headers that you listed as well as the Hooker headers have slip fit collectors. So if your putting those headers on your car and going to hook up exhaust be prepaired for exhaust leaks. While that pipes will carbon seal up some you can't wekd them up due to one of the pipes going around the control arm.
See my post in fabrication titles 1982 Silver State Project for my pictures.
I would recommend to get a set of headers from Dan Lemons. Welcome to Lemons Headers Online Dan did a great set of headers for my car. Mine were custom due to some stuff I wanted done. He has some great off the shelf headers that will work. You can told him that Brett Murphy refered you. They are not the cheapest but better then a Hedman or Hooker in my opinion.
Brett
Brett
redformula88
Oct 14, 2015 06:08 PM
