Summit mini starter
Car: S10
Engine: 383
Transmission: th 400
Axle/Gears: Stocker 10 bolt w/4:11's
Summit mini starter
Anyone have one? I just got ready to drive my 82 for the third time since the engine swap, but after cranking over twice the starter died. The bendix will still move, but the starter motor is toast- even jumping the solenoid from the battery lead does nothing. This thing had about 20 min cranking time on it. It was marked with an sri on the mounting block. Anyone elsi have trounble with these, as I have had good luck with outher summit products
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
Yeah, they're junk! My first one lasted 3 months and second one lasted almost a year. I had the first rebuilt by a local rebuilder and it's still going strong a year later. You may want to try going that route.
Car: S10
Engine: 383
Well, I just took the starter off the car and hooked it up to a charger, jumped the solenoid from the +, and she spun over. I then decided to take it apart to check the internals-everything looked ok, so I reassembled it and put it back in. No problems whatsoever. WTF? I know for sure it was a problem with the starter in the first place because it tested it the exact same way when it was bolted in the car and again when it was on the workbench. I didn't take it completely apart, just took the motor out of the casing. Now I'm wondering if there is a broken tooth or something floating around in there
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
i run the high torque mini starter that summit sells as the summit brand. i've had it on the car for 3 years with no problems at all. it has more crankover power and it's smaller and lighter.
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
