Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Summit shorty headers?
Old Nov 16, 2006 | 11:46 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
http://store.summitracing.com/partde...5&autoview=sku
anyone ever use these? i'm looking to spend as little as possible on some headers as long as i can have them fit my factory y-pipe. if they look like the ones in the pic then i should be able to make a pipe between the headers and the y-pipe to make it work right?
only thing i dont know off the top of my head is if my y-pipe is 2.5" at both collectors.
I have the L98 and dual cat y-pipe. dont know if its 2.25 or 2.5" up front.
i just want to do that and hook it up to my gutted y-pipe and flowmaster thats already on the car.
I'm not looking for performance, just a little smoother flow and some sound.
Old Nov 17, 2006 | 12:13 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
i think those are jsut hooker 2055s. i think....summit just takes brand named parts, puts their name on it and sells it for less. look at summitracing.com and tipe in HOK-2055 and compare the difference
Old Nov 17, 2006 | 01:00 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Definitely not the Hookers. The 2055s have 1 5/8" primary tubes instead of 1 1/2", a 2-bolt ball flange instead of a 3-bolt flat flange, and they come with a Y-pipe.
Old Nov 18, 2006 | 02:24 AM
jer4251's Avatar
Car: They all sit.
would those summit headers work with my stock pipes? with a little modification? 85 bucks is a good price for those right? i live close to summit to pick my parts up.
Old Nov 18, 2006 | 08:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The Summit headers are the same as the cheap Flowtechs. Don't waste your time or money. They fit terrible, have horrible build quality and will not work with your stock y-pipe. You will have to fab your own or buy their equally crappy y-pipe which is about 2% better than the stock y-pipe. Try a few searches about Flowtech/Summit headers. I have had them and in the end they cost me more money and time (because you need bolts, quality gaskets, drill the 02 bung, ect ect) than if I had started with a set of SLP, Hooker 2055's or Headmans.
Old Nov 30, 2006 | 01:29 AM
kaos's Avatar
Car: 91Camaro
Axle/Gears: Stock
The above statement is true, try not to cut corners with modifying your ride. Buying something with better quality is always better especially if you plan to keep the car and it will save you MONEY in the long run. Save up and get some good headers and y pipe and I guarantee you will be happier.
Old Nov 30, 2006 | 02:35 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I bought some of those headers,and there was hole in the weld where the pipes meet the collector,and the welding inside the collector was messy,but you get what you pay for i guess.
Old Nov 30, 2006 | 09:07 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I put the summit shorty headers on my new rebuilt 350 and they sealed great and everything looks good with them, no leaks anywhere. The only thing I don't like was that the black paint burnt off while breaking the cam in, so they'll probably rust quick, but hey thats pretty much any painted headers problem!
69GTOby
Apr 18, 2016 02:34 PM
Chad Speier
Sep 24, 2015 12:32 PM
aharvel50
Sep 21, 2015 07:31 PM
Night rider327
Sep 16, 2015 02:20 AM
hdis2002
Sep 8, 2015 02:52 PM
