Shift lights?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Shift lights?
Just trying to get some ideas on what people are using, I'am looking for something that's just the light itself not something with a tach. So let me know what you have and if you like it, maybe where you mounted it. Pic's would be great to if you have them!
Car: 84 Z28
Engine: Modded 350ci.
I recently picked up the MSD digital shift light.I dont have it mounted yet,but i'll be sticking it in the car soon.
It's fully adjustable,you can set the light to come on at different RPM's for 3 gears.It's got an LED display for programming the light and the shift light itself is about 3/4" across with 6 or 7 LED's filling the space.
It looks like a really good peice.I cant wait to trt it out.
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
the msd soundes good with the adjustments on it i am useing the auto meter with the RPM chips. it looks good next to the blower light. i'll look for pic.
Car: 89 GTA
With that digital msd one don't you need their digital ignition setup as well? Does sound pretty cool that you can do 3 gears separate, how does it know what gear your in?
Car: 84 Z28
I have no idea how it tells what gear your in.All i know is it says programable for 3 gears.
I believe it will work with any ignition.It has 3 wires to be hooked up if i remeber right. I will have to find a link to it for you on the MSD site.
Car: Pair of 92 Z28s
I was looking at the autometer shift lights but that with the pills i can just wait awhile. You guys think theres any difference going with the cheaper lights from summit?
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i have a proform light. it is from summit. works great. looks exactly like a light from a tach w/ shift light combo but you can adjust it on the back from 3000 all the way to like 9000. im pleased with it. it is off like 500 rpm but i think my tach is off i will find out when i put it on the dyno.
Car: 89 GTA
I was looking into this one http://www.raptorperformance.com/ looks to be pretty decent and small.
Car: 88 IROC
the only thing about that light is that it doesnt look like it can be adjusted very much. it looks like you would have to mount it where it is facing you but there really arent that many spots that you can have it mounted like that. ill snap a pic of mine when i get home and show you. i do like the led's and the size of that one though.
dhonda200
Aug 11, 2015 11:50 PM
