Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
TCI Torque Convert Lock up kit?
Old Feb 11, 2007 | 11:19 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
http://store.summitracing.com/partde...50+4294844569+
Anyone know how well these work?
Vacuum switch work good to unlock it?
I wanted to try the other ones but I have VSS in the transmission and the others require a mechanical speedo
So again how did it work out for you?
Old Feb 11, 2007 | 11:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It works about as well as anything else. It's somewhat similar to what the factory used on non-computer-controlled vehicles.
Old Feb 11, 2007 | 01:55 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I mean how does it work out automatically? I did not want to use a manual setup.
Old Feb 12, 2007 | 12:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It has a 4th gear pressure switch that's installed in the valve body to lock the TCC up automatically in overdrive, and a vacuum switch to unlock it while coasting or at WOT.
Old Feb 12, 2007 | 07:15 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Well hopefully it works as advertised since I just purchased it yesterday.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
gwade12
Aug 8, 2015 08:17 AM
