Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Megashifter questions...
Old Mar 22, 2007 | 01:46 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I just installed the megashifter on my car, and I love it so far! The one thing it doesnt say, or maybe im just misunderstanding it, is the cable for the shift lock (in the steering wheel) basically doesnt get hooked up in any way and just chills out in there?
Also with the cable adjustment... I basically have to screw on the metal thing to the cable, and move the shifter and move the tranny into the corresponding gear and it should slide out of the front hole?
Old Mar 22, 2007 | 05:35 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Megashifter questions...
okay, Adjusted the cable today. It shifts fine, a little hard actally, but im told it just needs to be broken in. The cable though, seems not right. They tell you to put that black piece (that slides into the shifter bracket on the tranny) in the front hole, and center it on the treaded portion of the cable. I had to move the shifter cable all the way forward, and thread that black piece all the way forward as well. Does this seem normal/
Old Mar 23, 2007 | 09:20 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I've got a Megashifter, put it in this past winter and quite honestly I don't understand your question. I can tell you it's a lot of fun to play with. I hope someone can help you.
Old Mar 23, 2007 | 09:27 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Man, just got mine yesterday, and it looks like a REAL PITA to put it in the car.....I know it will look good tho.......How many hours did it take you guys to put it in, and are there any real "issues" with it????
Old Mar 24, 2007 | 01:02 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
doesn't take more than an hour once the console is removed. Very simple install as well.
Old Mar 24, 2007 | 06:24 AM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Ill take pics and show you guys. It took my about 1 1/2 to install, and adjust the cable. It didnt seem to bad at all.
Old Mar 24, 2007 | 08:32 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Hi,In regards to the original shift lock cable,it does just stay disconnected.What you need to be aware of is if you happen to turn the ignition switch to off while the car is moving then your steering will lock.This is something that would'nt happen with the original configuration.B&M make mention of this in the instructions,also the shift is quite firm,but if you have to struggle with it check that the cable is looped correctly and not kinked or anything.I had to play with the tranny end of things for a while to get it right
but once you get it right it's great.I hope this helps.
Regards,
Alicat.
Old Mar 24, 2007 | 10:29 AM
BIG_J_420's Avatar
Car: 82 T/A
Engine: stock 350
do any of yall still have the templet that needs to be cut out of the shift plate? i kinda just cliped off a small peice of the shift plate so that i could get it in drive. I still cant ratchet it cause it hits the shift plate. thanks J
Old Mar 24, 2007 | 01:19 PM
bfox88's Avatar
Car: 90 IROC-Z
i cant get my wiring right....
Old Mar 24, 2007 | 04:17 PM
BIG_J_420's Avatar
Car: 82 T/A
Engine: stock 350
fat purple and yelloy wires go to the bottom 2 pins, and you blue and green wires go to the top 2 pins. You can go to www.bmracing.com and download the instructions off there.
Old Mar 25, 2007 | 10:24 AM
bfox88's Avatar
Car: 90 IROC-Z
ya i've checked the diagrams and everything over and over and it still wont start. come to the conclusion that it must be the relay so i'm going to try and replace it and see what happens.
Old Mar 30, 2007 | 02:33 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Well basically, Im out o adjustment on the cable going down to the trans. U have the bracket in the right holes, im just all the way out of adjustment on the cable, but in every gear, the cable moves in and out of the front hole like they want it to,,,
Old Mar 30, 2007 | 05:34 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Well if it only took you an hour to put it in, you are one hell of a mechanic.........Took me most of the afternoon..I still dont have the indicator working right, but I like it overall........BTW, mr cars wires were a different color than what the directions said, so I spent some time figuring out the wiring.......Tom
Old Apr 2, 2007 | 07:37 PM
alicat's Avatar
Axle/Gears: Stock.
Hi,Sounds to me as if the car thinks it is in gear,so i would look at the neutral start switch on the shifter.Also check if your reverse lights are on when the key is in the run position,you have to get the reverse switch just right.
Old Apr 3, 2007 | 06:24 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
agree with alicat. If your wired right one of you switches is out of adjustment. I had to call B&M for the wires too can't remember what they were. I installed it on my 92 Camaro. I'm in japan right now and the car is in Ct so i can't look at it to help. sorry
Old Apr 3, 2007 | 12:13 PM
bfox88's Avatar
Car: 90 IROC-Z
thanks guys but i got it. turns out i bought 2 relays and redid the wiring three times to find out that it was a dead fuse...
Old Apr 7, 2007 | 02:23 PM
Ucantcme57's Avatar
Do you need a manual valve body to run this shifter? I heard they are typically really hard to shift though. you said that they have to be broken in, anyone have this problem with being hard to shift and did it ever loosen up?
Old Apr 7, 2007 | 03:13 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
I'm just about to run into town to pick up some fiberglass, but I figured I would chime in. About 2 years ago I installed my B&M Megashifter, I since sold that car but it was a wicked shifter.
Anyways, I remember the install like i did it yesterday... So I'll pop back and give ya whatever advice I can
Old Apr 7, 2007 | 04:34 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, here's a little advice on the install.... did mine about 4 years ago in my '86 TA.
First, what I did ... instead of cutting the wires from the neutral safety switch and wiring up the little micro switches to the B&M, just unbolt the neutral safety switch assembly from the stock shifter and let it hang out with the wires still connected. Make sure the little lever on the neutral safety switch is all the way in the park position (all the way forward) and when you reinstall the console after installation, the neutral safety switch assembly tucks away nicely next to the B&M. The ONLY problem this causes is that now you can start the car in any gear which isn't preferable but if you're dumb enough to have your shifter in gear and try to start it then you deserve whatever damage happens anyway.
Second, on adjustment of cable ..... just make sure that you check that the black piece fits into the front hole in EVERY gear, don't take shortcuts. And when I say "fits" into the hole, I don't mean by forcing it into the hole. The black piece should slide in and out of that hole with NO effort at all in EVERY gear. If it doesn't then adjust the black piece on the threads AND the part of the cable in the bracket that bolts to the tranny pan.
If the shifter is super hard to shift then you don't have the cable adjusted properly or the cable is binding from being improperly routed down to the transmission. I know this because mine was hard to shift and I originally thought it just needed to "break-in". It broke in all right. Took it about a year or so and the cable broke. After I installed the new cable and adjusted it the correct way, I realized how much easier it was to shift and what had happened with the previous cable.
Old Apr 8, 2007 | 10:24 PM
Daishi's Avatar
Heres a bunch of random pics of my install, who knows maybe they'll help someone
Old May 16, 2007 | 11:55 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
YOU ARE THE MAN! I've been looking all over for some pics of the install piece by piece. Sweet!
Old May 16, 2007 | 02:23 PM
FireHwk's Avatar
Car: 92 camaro vert.
Engine: 305 TBI
Axle/Gears: 4th gen with 3:42
You may have the T-handle screwd on wrong Daishi. It took me a couple of trys to screw on right. its suppost to be facing straight not at an angle like that. Unless of course you like it like that.
Old May 18, 2007 | 07:08 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Got mine at that same angle, seems to feel better.
Old May 18, 2007 | 08:53 AM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Would it improve performance to put a Megashifter in even if you have a shift kit in the tranny?
Old Jun 18, 2007 | 01:07 PM
lovemyv8's Avatar
Car: '91 RS
Engine: 305 TBI
A bit,you can hold gears and change up quicker.
Old Oct 25, 2010 | 04:48 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
subscibed
Old Oct 25, 2010 | 05:58 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
lol you subscribed to a 3 year old thread (H)
Old Oct 25, 2010 | 09:12 PM
Engine: 383 stroker
yep it is my way of saving it....I made one like two days ago asking a couple questions and no one responded, this answers a few of of them but not all.
Old Oct 25, 2010 | 09:36 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
i too have been lookin for a thread like this one
Old Oct 25, 2010 | 09:39 PM
92Firebug's Avatar
Engine: 305 TBI
i noticed ur shifter only has 1 2 D then neutral....can it come with overdrive/????
Old Oct 26, 2010 | 04:38 AM
Slash's Avatar
yes, when you buy a megashifter It is originally just set for the 1 2 D. you pull a pin or w/e it then it turns into 1 2 3 D compatible. However it only comes with the 1 2 D indicator for the panel. You have to buy a 1 2 3 D indicator for the shifter separately
Old Oct 26, 2010 | 05:54 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I bought mine 4-5 mos. ago, it came w/ a 1 2 3 D indicator?? maybe they supply them now?
Old Oct 26, 2010 | 09:24 AM
92Firebug's Avatar
Engine: 305 TBI
Ok that sounds better, i will see if i have to buy one seperately.
Old Oct 26, 2010 | 08:18 PM
Slash's Avatar
dno, I got my shifter for free when i bought the car it was still in box(bought car dec09, box was alredi there) only had the 1 2 D. A nice guy on here sent me his 1 2 3 D indicator for free since he wasnt using it, due to his car only having the 1 2 D
Old Oct 27, 2010 | 08:51 AM
92Firebug's Avatar
Engine: 305 TBI
so what do you exactly have to do to install the Megashifter? where do u wire the red wire?
Old Oct 27, 2010 | 04:41 PM
Slash's Avatar
lols mine is still sitting waiting to be installed. I haven't had time/money. Not to mention its my Daily Driver, so can't take it apart >.>
Old Nov 16, 2010 | 08:55 AM
92Firebug's Avatar
Engine: 305 TBI
I finally got my shifter, and found the shift indicator that allows 1 2 3 D...but im really intimidated by the amount of small parts and i dont know how long it will last to install it. Help?
Old Nov 16, 2010 | 01:19 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
It took me just over an hour to install mine. Read through the instructions before starting. Get everything ready, understand everything you have to do, then do it.
Old Nov 16, 2010 | 03:04 PM
92Firebug's Avatar
Engine: 305 TBI
i know, i just dont want to wreck or break anything
Old Nov 16, 2010 | 08:51 PM
alicat's Avatar
Axle/Gears: Stock.
As the above,take your time,and make sure you know what to do before you do it.Follow the steps,and you'll be fine.
Alicat.
Old Nov 23, 2010 | 06:46 AM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
if you buy the megashifter that says its for a 82-92 camaro will it have the 123d indicator?
Old Nov 29, 2010 | 03:18 PM
  #42
3rdgenmaro's Avatar
Car: 88 IROC
mine did
Old Nov 30, 2010 | 03:26 PM
  #43
92Firebug's Avatar
Engine: 305 TBI
mine did
same with mine.
Old Dec 3, 2010 | 10:45 PM
  #44
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Old Feb 7, 2012 | 04:50 PM
  #45
RMR94's Avatar
Car: 92 camaro
Engine: 305 bonestock sbc
Transmission: 700/r4
http://www.youtube.com/watch?v=g8WaB...eature=related
Old Feb 8, 2012 | 07:22 AM
  #46
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
when i bought mine a few years back, it had 2 shift indicators; one for 4sp setups (like the 700r4) and one for 3sp (like the th350 or th400). dunno if they changed this though
Old Feb 8, 2012 | 11:26 AM
  #47
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
got mine a lil over a year ago and it came with 2 also...the 1 2 D came installed and I had to install the overdrive one..thought it was weird cause those years more came with OD then D. but whatever it is easy.
Old Feb 9, 2012 | 09:03 AM
  #48
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I bought mine in December and mine came with both.
The instal wasn't hard but there was alot of cutting I had to do to my bird and the shift plate ended up cracking on the driver side. You can't see it because of the shift boot, but it's there.
Old Feb 9, 2012 | 11:02 AM
  #49
Engine: gone
Transmission: gone
Axle/Gears: gone
the stock shifter plate? i always wanted to see one of these installed in a firebird because i dont know how'd they look in one.
Old Feb 9, 2012 | 03:24 PM
  #50
RyanJB's Avatar
I think that it fits Camaros better (based on the amount of cutting I did to the shift plate, and it not matching the template at all.), as well as the look of the shift plate B&M supplied.
Here's the crack...
