Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
replacement gas tanks
Old 05-01-2007, 12:55 AM
Kandied91z's Avatar
anyone?
Old 05-01-2007, 06:20 AM
formula_pilot's Avatar
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
Re: replacement gas tanks
I bought a tank from these guys: discountgastanks.com
Price was good, very fast delivery and fit was excellent- with one exception: I had to but a new gas cap, because the threads on the new tank were different than the old tank. The new tank has the same threads as a 95 Honda Accord tank.
Old 05-01-2007, 08:00 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
AAAH!!!
Rice Threads!
LOL!
well, at least they should be easy to find for a while. then i'll forget i need the honda cap when i go to buy a replacement cap......
thank's for the link, i'm gonna check em out!
I'm gonna need a pda by the time this car's done
Eric B
Old 05-01-2007, 08:11 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
4th gen plastic tank an option?
Old 05-01-2007, 05:05 PM
Kandied91z's Avatar
i don't want to have to change over the fuel system lines.
just what i was looking for. the same tank on other sites and ebay go for $250 plus. i found it cheapest at rockauto.com so for for 169 +shipping and this site you have here is only $165 shipped.
quick question: how close is the gas tank in look to the factory? any problems with it. i need to pick up a new sender as well. i would like to save money but i want the right tank also. new from gm just the tank is $450 and i don't want to mess with one out of a wrecked car.
Old 05-02-2007, 06:16 AM
Car: 89 Formula
Engine: LB9
The tank looks just like the factory tank. My sending unit assembly was corroded very badly, so I bought one from the same people. The sending unit fit well, but the gas gage is terribly inaccurate. It reads dead full for over half a tank then drops like a brick. From GM factory, my car only read full for the first 1/4 tank, then dropped. The indicated level could be adjusted by bending the arm for the float, but I have too many other things I would rather do than drop the tank just for that.
Old 05-02-2007, 08:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I wish I saw this thread a couple days ago. I just bought 2 gas tanks for my truck and that site could have saved me some money.
Old 05-02-2007, 08:29 AM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
www.nastyperformance.com - 93-97 F-body tank
I needed to replace my tank too, but I'm not fond of the in tank pump etc, so I looked for a sumped solution.
I used a C5 vette fueling receptacle in place of the stock one, with clear fuel safe vinyl hose connecting the tank and the fueling receptacle. Specify 0-90 ohm sender.
Old 05-02-2007, 02:44 PM
Kandied91z's Avatar
that's different, where did you put your exhaust.
Old 05-02-2007, 03:41 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
I have dual 3" aerochambers that dump in front of the axle, and I avoid speed bumps like the plague, but I don't drive my car daily. It's a provisional solution until I finish some re-wiring and suspension projects I am doing on my car right now and then I'll start on a more permanent side exit spintech solution for exhaust.
Old 05-03-2007, 01:43 PM
Kandied91z's Avatar
gotcha... interesting, looks nice. side exit just isn't possible for me.
anyone else have any experiences with purchasing new tanks?
Old 05-03-2007, 04:52 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
wow, that looks pretty sweet Dz.
Old 05-10-2007, 06:51 PM
drjohn981's Avatar
Car: 86 iroc z28
Transmission: t5
Axle/Gears: 4.10 10 bolt posi
Tankstopan.com
Oops - tankstopans.com
Infested
05-22-2018 11:56 PM
Orr89RocZ
04-25-2016 08:28 AM
Andrew6.688
12-13-2015 10:59 AM
mustangman65_79
09-01-2015 03:51 PM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: replacement gas tanks
