400 Hp 350 cid Motor for under 3 grand
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
I just saw this on the SPEED CHANNEL, Yearone.com has a crate engine assembly putting out 400 hp for a little under 3 grand...i believe all u need is the carb,water pump, and pulleys and your set!
Go to this page --> http://yearone.com/serverfiles/fbshopmain2.asp?cat=G
Go down a little bit and click the picture where it says Yearone Power crate engine assemblies and then its the 2nd engine down...
My 305s pushin aabout 155 k miles right now and when it goes im gonna get this.
Does anyone else here have it and if u do how is it?
1 Post
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
Re: 400 Hp 350 cid Motor for under 3 grand
All their Crate motors are priced very well....that 502 505hp is only $7700...the 572 710hp is $9990.....when comparing these to other manufatures they are a few thousand cheaper!...
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
not bad prices at all. I am selling my motor, 500 H.P. for 3500 so its good prices
Engine: gone
Transmission: gone
Axle/Gears: gone
i dunno i priced crate motors and its always cheaper to build it youreself
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Another idea is to buy the basic shortblock with good internals as a package. Then get whatever parts you want to throw on and it will save some time and money and you can still put together whatever you want.
Engine: 305 5.0 LG4
Secondly with a crate motor there is no guess work, these things are dyno tested and ready to go.
But i would love to build my own monster someday.
Engine: gone
Transmission: gone
Axle/Gears: gone
oh ok i guess. Building an engine is soooo easy once u build one you'll be like pl get paid for this?
1 Post
Car: 1989 Chevy Camaro Iroc-Z
Engine: L98 B2L 350 TPI
Transmission: 700R4 auto
Axle/Gears: 2.77
This is the onfo i been looking for, finally a crate in my budget. Of course my engine will stay FI. Ill use the edelbrock base for vortec heads and the runners, but my only question what size injectors should i use as well as the TB (stock 52 or 58)
1 Post
Axle/Gears: 2.77
I did notice that the engine on year one doesnt give a lot of intel on the engine, like the style of the heads and the cam spec......kinda makes it very hard for sells cept the fact it claims 400HP+
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
That aint 400 HP. It uses simple parts. Vortec heads and an LT4 hotcam.
I'll bet its 400 gross HP. 400 Hp without water pump, alternator, open carb and probably headers. I dont think anyone dynos without longtubes on.
Still, its a nice affordable longblock.
1 Post
Car: projects.......
400hp is fairly easily obtainable with vortec heads and a mild cam.
...and yes, stock injectors an throttle body are good for over 400hp.
Car: z28
Transmission: pro built 700r4 (road racing kit)
Just wondering but if you were given $2999.00 (the same as what this engine cost) how much better of and engine could you build? And would it really b worth it?
Also from what I’ve seen isn’t this pretty much the best bang for ur buck when it comes to 350 crate motors?
I had my long block built lt4 hot cam and vortec heads and one pc rear seal block for 1500 $ get a local professional machine shop to do the build and shop for parts
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
That was $1500 before parts? How much did you spend on parts?
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Sorry but Year One = empty wallet. Year one may have a lot of stuff for the f-bodies but as usual all their stuff is way over priced. Granted this motor might be a decent price but it is one of the few things.
Engine: SBC
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
