what is the best oil filter for a 1989 camaro?
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
i know this seems small and meaningless compared to other topics but i read a review on here awhile back about a test they did on air filters and oil filters-anyways i cant find it so please let me know the best oil filter(already have k&n AIR filter) to use from now on and your reasons behind it please
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: what is the best oil filter for a 1989 camaro?
With me I tend to go with K&N for all filtering needs...except in fuel...thats walbro for me.
I use K&N Gold Filter 4.6" height and 3.770" diameter.
I am looking into an oil filter relocation kit....tuck it away a little bit...and for easier access.
Also look into a FILTERMAG. I havent used one but heard they work just how they say...its a piece of magnet that goes around the filter to pull particles away from the oil...and out of your system....check it up on GOOGLE and Im sure theres pictures of the particles...I've seen some but dont remember where...maybe a summit mag.
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
amyone have any luck with bosch??????
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I would say AC DELCO and K & N.
Car: 1992 trans am tpi 350
Engine: tpi 350
fram here, but they seem to like to crush on me when taking it off, so im gonna try a K&N next
I've always used Fram. What do you mean when they crush, stagefright? I've never had any issue with them, and I use them on all of my cars...
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
well i put a bosch oil filter on it already and i decided to try the new castrol gtx anti-sludge oil
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
K&N almost always, occasionally AC Delco.
88bullet (04-27-2020)
Engine: tpi 350
when i go to take the old one off the filter tends to crush uptop when i go to loosen it. dont know why they crush on me, but ive found a better filter wrench actually pliers thats works really good.
Engine: gone
Transmission: gone
Axle/Gears: gone
fram filter suck, they have cardboard reinforcements. i use a kn filter for a chevy 350 truck, longer more filter surface. if you cant afford kn id use a wix filter. why would u need to change a filter location on a 350 they are in a easy location
Car: 89' IROC-Z
Engine: LO3
When I get longtubes I want to relocate it....I have seen many pictures of Oil Filters right by the tubes...so I dont want it to get extremely hot and dont want any clearance issues. Stuff like that is why I want to relocate...but l8er...not right now.
1 Post
Car: 85 IROC-Z
Engine: 406
Axle/Gears: 9" 411
AC Delco on my all GM cars and trucks
http://minimopar.knizefamily.net/oilfilters.html
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
wix or k&n.....i used to be a firm believer in fram until i took one apart. cardboard and paper crap the filter is made of, its sickening.
I only use K&N oil filters on my cars, along with mobil 1 oil.
You can use the same filter I use on my LT1. The K&N HP3002. It holds an extra 1/2 quart of oil and it has an anti-drainback valve (which the standard size K&N HP2002 oil filter doesn't have). Also at all of the stores that are around here that carry K&N oil filters, the hp3002 costs the same as the hp2002.
Comparison:
http://www.knfilters.com/search/prod...x?Prod=HP-3002
http://www.knfilters.com/search/prod...x?Prod=HP-2002
Comparison:
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
AC Delco only the best
http://www.acdelco.com/parts/filters/oil-filters.jsp
I use a K&N HP3002 on my Camaro, but not on any of my other cars. At over $10/each, I'm too cheap, but on the Camaro I only change the oil every other year (at most), so the $10 isn't killing me, plus the nut on the bottom of the filter makes my life WAY easier trying to get a filter off that's been on there for 2 years.
On everything else, AC-Delco PF35. For a while the PF35 filter changed and was a shorter, cheap filter, but then I started seeing the original big ones back on the shelves so I grabbed a half dozen of them. As far as I know though, the original big ones are still what's being sold.
Wix, Puroilater and Napa brand filters are also very good filters.
Just stay away from the Fram junk. Penzoil filters are Fram filters with a different paint job.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I only use NAPA filters. It's my understanding that NAPA filters are re-badged Wix filters. I've seen in many places that Wix is top notch next to maybe Amsoil.
Engine: gone
Transmission: gone
Axle/Gears: gone
napa filters are same as wix, just like thier belts are gates
Car: 1986 IROC-Z
Engine: 305 T.P.I.
I've Never had any problems with fram........
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Fram has always been good to me
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
heard enough horror stories and seen the cardboard, ill never run any fram filter, i use a PF454 on my car
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
Has anyone tried the wix racing filters, i'm going to try them. It's number 51061r.
Can someone tell me if I need a filter with an anti drainback valve? I think not, but I don't know for sure. thanks
AC Delco oil filters. # 35 and 454 are the smaller ones while 1218 is he larger. All AutoZones carry them. I make anyone who comes to autoZone with a chevy small block buy it. For the price and quality they can not be beat. If they weren't good they would not put them on the $60,000 Corvettes.
Car: RS
Transmission: 4L60
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
I steal mine from vic_V8. He rarely changes his oil sooo he don't miss 'em.
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
AC Delco PF1218 for me. My '85 Z28 goes through the traps at 7,000 rpm so I'd say the PF1218 is well suited for a daily driver.
Car: '91 RS
Engine: 305 TBI
My feeling is use any good brand,just change it and your oil every 3-4000 miles.
Car: '82 Camaro Z28
Engine: 383
Axle/Gears: 3.73 with powetrax
Napa Gold all the way (Wix) Ive cut apart all kinds of filter and Napa/Wix have the best looking element. Fram is junk and if you get a "suregrip" filter its hard to get some oil filter wrenches to fit.
I remember reading an article on oil filters about 10 yrs ago. It's been a long time, but I do remember that AC Delco, K&N, and Wix were by far the best and after reading the thread, I vowed never to use ANY FRAM! They are terrible, even their best filter sucks! I wish I would have saved that article for this thread!
I worked in a quick lube my first summer of college. I got really bored one day and cut all the filter brands open to check them out. Stick with OEM filters, WIX, Mobil, and K&N. Never ever ever Fram!!!! It's a can of garbage. OEM filters (AC and Motorcraft) have metal caps holding the filter element together inside. Fram's are held together with a rubber band. LOL
Car: 1991 z28
Engine: l98
ac delco pf35l or pf1218, theyre the same size. on my other vehicles, ac delco or knn and mobile 1 oil for all my cars
Car: 92 camaro,99 s10
I've always run Delco,K&N,or Mobil 1 on my "fun stuff" (camaro and el camino)
On my 99 s10 with a 2.2L i'm running a fram it claims to have a 94% filter efficenty rating. And at 120hp in the bone stock truck i'm not turning 10 second 1/4's. So far no problems w/ Fram on the daily driver.
#42
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
Usually A Wix/Napa Gold, AC Delco or K & N for me.
#43
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I typically use an Amsoil EaO filter (uses synthetic nanofiber media from Donaldson and has a nice solid casing)
If I am not running one of those filters, it is either a Wix, Hastings, or Delco,nothing else.
#46
1 Post
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I dont think it really maters. Only a couple companies makes oil filters and puts the name on what company ordered them.
#47
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I just started using one of these http://www.gopurepower.com/store/ Nice but a fair amount of coin.
#48
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
for air and oil I like to keep it all GM but I really like the Castrol oil though..
#49
wix.. the napa gold is a wix relabled.. or like this week in a pinch a pepboys pure one.. ive heard of the frams check valve failing
#50
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
i use the mobil 1 filter it has the highest burst rating on it and is the best in my opinion and in the opinion of my fellow co workers that have mustangs and camaros.... thats all we run on our vehicles and thats what i tell the customers at the parts house i work at... i have never had a problem from the mobil 1 filter and i change it every 3,000 miles....
