Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Does this cam sound too big or just right?
Old Dec 3, 2000 | 10:23 AM
theformula's Avatar
Check out my mods, its on a SD 305 TPI
COMPETITION CAMS CAMSHAFT SPECIFICATION SHEET
PART # 08-304-8
GRIND NUMBER: CS 266H-R14
ENGINE:CHEVY SM BLK 305-350
GROSS VALVE LIFT .500 .510
.006 TAPPET LIFT 266 276
VALVE TIMING OPEN CLOSE
AT .050 INT 5-BTDC 35 ABDC
EXH 48 BBDC 8-ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 110 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 210 220
LOBE LIFT .3330 .3400
LOBE SEPARATION 114
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
Old Dec 4, 2000 | 05:31 AM
Novaguy76's Avatar
That cam would be a very good cam for your set up. You might be supprised at whaat yo could get out of it.
Old Dec 6, 2000 | 12:12 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
I think this cam is a little too big for you. First of all, you need to make sure you get a cam that is compatable with your computer. The best thing to do is call Compcams and ask them for their recommendation. That cam may be okay for a 350 but I think you might have some drivability problems with a 305.
PART # 08-304-8
EXH 48 BBDC 8-ATDC
INTAKE EXHAUST
LOBE SEPARATION 114
sweet_87_iroc
Sep 25, 2015 10:01 PM
lt1z350
Aug 28, 2015 05:57 AM
bdads
Aug 24, 2015 06:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
