Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Who makes a nosiey gear drive timing set for out cars??
Old 12-09-2000, 12:22 AM
Dan87IROC-Z's Avatar
I looked in Jegs and Summit, the Edelbrock, Pete Jackson and Dynagear are not made in the *nosiey* configurations for our cars with the roller cams, just regular old small blocks.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old 12-09-2000, 07:52 AM
Lounge Lizard 6's Avatar
Just a note...
If you are still using the knock sensor in your setup you will need to de-sensitize it. The gear drive will likely cause it to retard your timing.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old 12-09-2000, 08:06 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
No one makes a noisy gear drive for roller cammed engines. The best you can do is a Pete Jackson quiet gear drive. There are a lot of guys out there who believe or been told that we cannot run a gear drive with a knock sensor. This is not true. I've run one for almost three years.... no false knock confirmed by Auto Xray. I also know a handful of others who have run this gear drive successfully.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old 12-09-2000, 09:31 AM
theformula's Avatar
Dan, save yourself the trouble and just go with a double roller timing chain.
I've known quite a few people whos car never ran quite correctly again with the gear drive.
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old 12-09-2000, 10:14 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Had a gear drive for the most of four years.(switched to a true roller for a bit but when back to the gear drive)
No false knocks and no timing retard....
And just the right amount of whine...
And who says we can't put them in our car??? I'd love to show them it can be done...
I have the Pete Jackson quiet gear drive... Easy to install too..
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven.com
Old 12-09-2000, 03:03 PM
Tom Keliher's Avatar
OK, you want a noisy gear drive? Here is what you can do........
Buy the "quiet" Pete Jackson gear drive. Then, send it back to Pete Jackson in Glendale, CA and tell him you want it converted to the noisy type. The only difference, according to Pete who I talked with about this last year, is the machined cut of the gear teeth and he will swap them for you so you can have a noisy "roller cam" gear drive.
Old 12-09-2000, 05:52 PM
HotRodCamaro2K's Avatar
Or you could buy my Pete Jackson Gear Drive (noisy one) for $80 and I will pay for shipping.
Old 12-10-2000, 02:57 PM
It's not the same for non-roller cam engines.
Old 12-10-2000, 04:23 PM
......it's from non-roller...
Old 12-10-2000, 04:26 PM
specialized
06-18-2022 09:26 AM
midge54
12-27-2019 04:14 PM
thefirebirdm@n
South Central Region
09-14-2015 01:45 PM
TheExaminer
08-26-2015 04:59 PM
86Base
08-08-2015 01:34 PM
Quick Reply: Who makes a nosiey gear drive timing set for out cars??
