accel digital ignition
Car: Damn
Engine: This
Transmission: New Stuff
anybody running an accel digitial ignition
as opposed to msd 6al or other.
it is cheaper than the msd boxes and has more features.plus comes with matched coil.
comments, good-bad?
88 CAMARO RS
87 IROC-Z DRIVETRAIN
305 TPI, 700R4, 3.73s
ported plenum, performance resource chip,edelbrock TES Headers and cat-back, K&Ns, AFPR, rest is stock.
15.0 @ 92.5 (bald tires)
comments, good-bad?
88 CAMARO RS
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am also seriosly considering using this ignition since it seems to be such a value. (usually means piece of junk from rice land)
james
88 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
no MAF screens, no cat, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
homemade ramair.
james
88 T/A 305 TPI--
homemade ramair.
comments, good-bad?
comments, good-bad?
1989 Formula 350
13.95 @ 98.0
SLP,Edelbrock,Accell<Flowmaster,ect.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I got mine about a year ago. Make sure you get the one for your car, NOT the universal. The car specific one uses factory quality connections and plugs right in. It will take you longer to figure out where to put it than it will to hook it up.
Nice unit and it has the rev limiter right in it. I like it a lot and noticed a difference with it. The motor revs up a little quicker.
Overall, i am very pleased with it.
Car: 89 IROC-Z
Engine: 383
I've heard that the Accel box is pretty loud. People have told me that you can hear it "ticking" a lot. I'm not too worried about that because I'm sure I won't hear it over the exhaust, but I was wondering if anyone else heard this? Also has anyone had both the Accel and an MSD system? What did you think head to head?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
--RPM Racing--
Car: 1988 Trans Am GTA
Engine: 383
I've heard nothing but good things about the Accell, go for it.
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 2.5" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Veiw my car at:
http://www.members.tripod.com/~btessier
[This message has been edited by speed88 (edited November 28, 2000).]
88 GTA
L98 350
700R4
3:27 axle
MODS,
Veiw my car at:
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
The Accel bos is a little noisy but you really don't hear it unless you listen for it. I had the MSD 6A and switched from that to the Accel box and noticed a difference. Take that how you will.
Car: 89 IROC-Z
Engine: 383
Is that a good or bad difference that you noticed?
--RPM Racing--
--RPM Racing--
Car: Damn
Engine: This
thanx guys.
the accel unit sounds very good now, i think i'll probobly go with it.
i'll tell what improvements i get in the quarter.
88 CAMARO RS
88 CAMARO RS
Car: 89 Formula 350
Engine: 360 / HSR
I've had two Accel 300+ systems and they were both pretty loud. Mounted on the firewall it was noticable from inside the car.
Why did I have two Accel boxes? The first one caused a miss at cruising speeds. I called Accel tech and they told me "that happens a lot with the Mustang crowd." They suggested I disable the multi-strike feature. I did and it made everything worse.
So they sent me a new box and it did the same thing. I never figured out why, it was hooked up properly, I triple checked everything. Back to Summit it went. I wish it worked, the car felt real strong at WOT with the Accel box.
Jed
89 Formula 350
Jed
89 Formula 350
Car: Damn
Engine: This
that's the one!
88 CAMARO RS
88 CAMARO RS
efiguy
Sep 27, 2015 01:30 PM
