Do i need this for a Hydraulic cam?
Car: '84 Z28
I found a nice hydraulic cam but then i found this, it says i need this for early non roller blocks, what does that mean???
http://www.lingenfelter.com/store/l200105000.html
thats the link, any help is apreciated
thanks
casey
p.s. oh, just out of curiousity, what do you guys think the best compression ration would be for a TPI350? (1991 if it makes any different) the current CR is 9.5:1, but i'm rebuilding the motor, and need to know if a high would b better, i don't plan on blowing it, completely n/a, though it might get nos in the near future
thanks
casey
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Do i need this for a Hydraulic cam?
its used for the flat tappet cams. A good compression would be in the low 10's cr for a screaming small block unless you want a supercharger, than your going to want to go into the 8's
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's not for flat tappet cams, it's for putting retrofit roller cams into non roller blocks.
that is used for reto-fit roller application i use a roller cam button myself
http://store.summitracing.com/partde...0&autoview=sku
