Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
pro charger
Old Sep 4, 2009 | 07:24 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
pro charger
im looking to switch to a pro charged system this year and i was gonna start buying some of the stuff needed and i was curious if all the head units had the same bolt pattern for mounting. like if i were to buy a head unit off of a 95 mustand will it bolt up to the bracket im going to need
Old Sep 11, 2009 | 09:42 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Re: pro charger
I believe the brackets are different between cars. the head units should be the same thing. Your bracket will have the mounting holes in different positions to position the head unit in the right place.
Old Sep 11, 2009 | 05:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: pro charger
correct, a mustang headunit when bolted to a f body bracket will not yield the proper angle for the outlet of the head unit.
Old Sep 25, 2009 | 05:51 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: pro charger
ok heres the trickie part or so i think sorry it took so long to respond theyve been working us like crazy. ive got the 91 camaro but its got a 1st gen sbc in it. do they make a kit that will work for this setup?
Old Sep 26, 2009 | 12:01 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: pro charger
yup, I have one. I recommend calling procharger directly when your serious with some cash, and talk to them, they can help you out best!
Old Sep 26, 2009 | 05:35 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: pro charger
ok i will most definately do that. what setup do you have and what kind of numbers are you pushin out. im getting my motor rebilt within the next couple of weeks what kind of compression should i be going for and what kind of cam? and just out of curiosity roughly how much cash did you put out for the whole kit
Old Sep 26, 2009 | 09:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: pro charger
I have a basic f1a procharger kit, 12rib belt.
I had to convert all my accessories to vbelt though, you will lose your stock serpentine setup. right now i have 7psi and it feels 500ish, no dyno yet my trans went out. i built the engine for 15psi max and that should net me 600-700.
i have 8.5:1 CR, and a comp 236/248 duration cam.
Old Sep 26, 2009 | 11:06 AM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: pro charger
same here running 10lb boost ...... stock 700r4 + pro charger = no more 3-4 clutches ..... mine went about 3 months ago
Old Sep 26, 2009 | 01:06 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: pro charger
The head units bolt patterns are specific to the head units, not to the car it is used on.
The P600B uses a specific bracket and has it's own bolt pattern. 4 bolt hose in a square.
The Oil Fed Head, ie P1 D1, units use a bracket specific to them. Its a wide U pattern
The Self Contained, ie D1SC P1SC F1, units use a bracket specific to them. A narrow U Patter
There are standard and reverse rotation blowers, Also there are 3 Mounting angles. 10 12 and 2 O clock
You need the bracket designed for the 3rd gens which is only "bolt on" with the serpentine setup. It uses a standard rotation blower setup for the 2 o'clock mounting position.
Old Sep 27, 2009 | 11:51 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: pro charger
hey thanks for the information its alot of help. i have an electric water pump is the standard mounting for the head unit going to work with this and when i buy this does it come with a new crank pulley and if so does anyone have a picture. just kind of curious as to whether it runs on its on belt and how i would hook my powersteering up with that big ol thing in there. what kind of lsa is on that cam and lift as well. my objective this year is to get the motor rebuilt for the procharger break it in off of the boost and then boost it like you said around 15 lbs. im looking to make somewhere around 700 hp my trans is built for 800 so i dont want to push it. ummm oh one more thing i was reading up on these things and some people claim to have crankshaft snout problems has anyone else had this problem thanks
Old Oct 12, 2009 | 09:40 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: pro charger
one guy on here had that when used with a 12 rib setup but that was on a cast crank im pretty sure not a forged crankl
Grant2k
Apr 4, 2016 08:21 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
jbates346
Sep 22, 2015 05:22 AM
Formula_88AE
Sep 3, 2015 01:47 PM
