Founders Performance Control Arms
#151
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: Founders Performance Control Arms
been on founders website a number of times. still contemplating on what i want. umi, founders, hotchkis, edelbrock, so many choices so little time. need to figure something out.
#152
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
anyone got the ones with the swivelball joint? just curious i saw spohn and umi have a swivelball joint arm and i heard they were really good but founders i havent seen on any car...also can i get away with rod ends on street?
#153
Car: 1987 Trans Am
Engine: LQ9/L92
i grabbed a set of the single adjustable LCAs & Panhard and they are a poly/rod mix. poly should allow a little more flex for a less jarring daily daily driver while still having the more solid rod end on the other side (in my case at the rear)
#154
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I have 35-series 17"s, run double rod-end rear LCAs & a double rod-ended PHB UMI pieces on my daily driver & it isn't nearly as bad as I thought it would be. Over a year now with them now & I'm very happy that I chose the fully rod-ended pieces.
#155
Car: 87 iroc
Axle/Gears: stock
i could care less about the ride quality obviously since its solid metal its gonna be rougher....i was worried about strength for a daily driver but thank you guys for putting my fears to rest...now ordering double adjustables
#156
Car: 1991 Camaro Z28
Axle/Gears: LS1 3.23
I bought Founders LCA relocation brackets, LCA, and single adjustable panhard rod. I installed them both but I wanted to make sure I installed the panhard rod correctly. How do I know its adjusted correctly? Do I just install them like the stock one? If i did that, wouldn't it be just like I have a stock one? My car is lowered so that's why I got the adjustable one. Thanks
#157
Car: GTA
#158
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Just got my dbl adjustable lcs'a and panhard kit. Awesome fitment, the only problem I had was they sent the standard busings instead of the offset ones. I contacted them this morning, and they have already contacted me back and have the offsets in the mail to me.
DO NOT HESITATE!!!!
DO NOT HESITATE!!!!
morrow
01-13-2024 12:29 PM
3rd, arms, bar, control, ebay, fbody, founders, foundersperformancecom, gen, lower, panhard, peformance, performance, review, z28com
