Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
mechanical fuel pump to electric fuel pump
Old 04-01-2010, 10:36 PM
NEWBREED's Avatar
I have a 83 Z28 with a L69 package, I recently got rid of the quadrajet carb and the computer stuff. I added a eldelbrock hi-rise with a edelbrock 600 carb. My car came stock with a mechanical fuel pump mounted on the engine block, it recently went out. I want to replace it with an electic fuel pump. My question is.....I have four lines coming out of the fuel tank, one is for the fuel feed, one is for the return, one is for the vapor, and one is for the vent....I know I need the fuel feed and the vent lines, do I need the vapor line since it went to my charcoal canister, and I got rid of it? And also what do I do about the return line since an electric pump doesn't have a return line. Also one more thing where is the best place to mount an electrical fuel pump....Any help would be appreciated, THANKS!!
Old 04-02-2010, 12:57 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: mechanical fuel pump to electric fuel pump
a holley red pump should work well with a "dead head" regulator. just plug the return line to keep it clean if you ever decide to reuse it. electric pumps like to push so mount it close to the tank.
Old 04-02-2010, 10:11 PM
NEWBREED's Avatar
What exactly is a dead head regulator?? Can you please explain...Thanks!!
Old 04-02-2010, 10:15 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just buy a holley blue and it comes with a regulator, install it right side up since upside down it'll burn out.
deadhead regulator = returnless style
keep the lines away from heat and exhaust and you'll be fine.
92camaroJoe
07-29-2023 07:57 PM
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
sweet_87_iroc
09-25-2015 10:01 PM
TreDeClaw
08-14-2015 06:58 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: mechanical fuel pump to electric fuel pump
