Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
2 Pc Timing Chain Cover...
Old Dec 7, 2010 | 03:50 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Has anybody used a 2 pc timing chain cover?
I was thinking of using one with my latest build because I can't imagine dropping the oilpan again and fighting with that front oilpan gasket to change a Camshaft.
I have 2 Cams and was gonna use the larger XFI 268 in my 383, but if I don't like the feel of it I'll go with my current LPE 211/219.
This is what I had in mind.... or something like it...
http://www.summitracing.com/parts/SUM-G3230/
Old Dec 7, 2010 | 03:57 PM
Twin_Turbo's Avatar
Re: 2 Pc Timing Chain Cover...
Yes, I have had a comp cams 2 pc for years, that summit thing however looks like a cheap stamped POS! If you want to run a roller and a button get something more sturdy (or you have to get a water pump w/ a cover preload stud)
Old Dec 7, 2010 | 05:31 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks for the quick response...
The Summit item was just an example of what I was talking about...
I shouldn't need the cam button because I have a stock roller block with a camshaft locking plate to hold the Camshaft back in the block...
I figure that a 2 pc timing chain cover would be a "MUST HAVE"....
can't believe that I didn't do this with the last build!!!
Thanks again!!!
Old Dec 7, 2010 | 10:06 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I dont pull the oil pan when I do cam swaps on chevy's but i guess I would buy a 2 pc just to make it a little easier when I do my next full build.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
