halo headlight replacements
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
http://cgi.ebay.com/ebaymotors/85-92...#ht_8211wt_864
has anyone used these?
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: halo headlight replacements
These are the ones that I used......Pilot 4x6 Wl-HL12
http://www.pilotautomotive.com/Produ...7438&PCID=1070
http://everythingcarparts.com/4x6_H4..._by_Pilot.html
They even sent extra bulbs on accident! Scored them on ebay IIRC- did them at the same time as my header panel.
There's a thread going already you might want to check out...
https://www.thirdgen.org/forums/afte...vy-camaro.html
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have a set of those Pilots too. I've burned out the HI/LO driver side bulb twice, since then had to replace that housing because the reflective material started to burn off, leaving a nice black residue, the passenger side isn't far behind. Plastic reflectors aren't worth it, I'm pulling these as soon as possible and installing some E-Code Hella H4 aluminum housings without the halos.
http://www.rallylights.com/SearchRes...CategoryID=364
The housings and reflectors are plastic. The lenses are glass. Using the recommended 55/60W bulb, it still burned the reflector.
Ghettobird52
Jul 5, 2024 11:18 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
