Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Jensen Head Unit
Old Aug 5, 2011 | 09:59 AM
Mifarrell5's Avatar
Car: 1989 camaro rs
Jensen Head Unit
Hello i just got a 1989 Camaro RS. The kid before me put in a jensen vm8013 head unit. the only problem is that every time you shut the car off an back on it resets and you have to turn it on manually, it doesnt just come on like it should. I tried to see what was going on with it so i popped it out but its just a wirey mess under there. Im thinking about getting a service manual, haynes or chilton, any suggestions or input would help. Thanks.
Old Aug 5, 2011 | 10:18 AM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Re: Jensen Head Unit
sounds like whoever had it before didnt wire the memory wire correctly...i think its the yellow...or red you should be able to google it and double check but you have to have power to the constant wire ( memory ) or the unit will reset itself all the time. Should be a pretty simple fix
Old Aug 5, 2011 | 10:45 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i agree, sounds like it the constant 12v was not wired correctly. here is what you're supposed to have, hope it helps:
Old Apr 21, 2016 | 06:44 PM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
Does anyone make a plug-n-play harness for their unit? I have a hole to fill and don't want to screw up the factory wiring.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ZsTransAm
Aug 11, 2015 07:30 PM
