Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
B&M Mega Shifter series 80692
Old Nov 4, 2011 | 11:48 AM
howard618's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Transmission: 700 r4
I just recently installed a B&M in my 84 firebird after my shifter cable went bad. After installing, the car wont turn over, i have tried quite a few opions, i shorted out the neural saftey, tried knocking on the starter, tried jumping it, its still not starting. any advice ?
Old Nov 4, 2011 | 12:30 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: B&M Mega Shifter series 80692
not cranking? or not starting? not cranking seems to be either a bad battery, bad starter, or more than likely you wired up the switch incorrectly
Old Nov 4, 2011 | 06:57 PM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
Make sure you are in park. You wont believe how many people will call my work and say their car wont start I go there with a jump pack and they dont have it in park.
Old Nov 6, 2011 | 03:05 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Check how you wired the reverse lights switch,because if its wrong,then even though its in park visually,it wont start as the ignition thinks it is in reverse,if that makes sense.
Alicat.
Old Nov 7, 2011 | 12:41 PM
howard618's Avatar
Car: 1984 firebird
Engine: 2.8 v6
I checked the starter and battery, thats good. As for starting it in park i took off the shifter cable and manualy put the trans in park and neutral, still dident start. All the wiring im 98% sure its correct, ill take another look at it though.
Old Nov 7, 2011 | 01:50 PM
jhp73's Avatar
Car: 1987 iroc Z-28 5.7 TPI
Engine: 5.7 TPI
Do you have alarm system? If you do it will not start if you disconnected battery. Happened to me after alt installation. Cure was disconnect - cable turn key to on position reconnect cable then start.
Old Dec 11, 2011 | 08:23 PM
djohnson2341's Avatar
Car: 89 Trans Am GTA
Axle/Gears: 3.27 Posi
Did you ever solve this problem? I've had similar issues with my megashifter. The previous owner said I have to SLAM it into park so it will start. Quite frequently, even while the car is in park, I will have to hit the shifter forward to start her up. I can't decide if it is wiring or if the entire shifter needs to be moved forward a little bit. Let me know if you had any luck.
Old Dec 14, 2011 | 12:56 PM
skully-bones 13's Avatar
Car: 1985 Camaro IROC-Z
Engine: 305 w/ 4 barrel carb
Transmission: brand new 700r4
what if you have an automatic and you can start it in any gear..lol..including reverse, drive, 1st 2nd etc
Old Dec 22, 2011 | 06:22 PM
howard618's Avatar
Car: 1984 firebird
Engine: 2.8 v6
nope, i never solved it, i have a buddy coming out this Tuesday who is pretty confident he knows whats going on. I will keep you updated.
Old Dec 22, 2011 | 06:41 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
you have to adjust your shifter cable to where it grabs park all the way.
Old Dec 22, 2011 | 09:22 PM
jhp73's Avatar
Engine: 5.7 TPI
Hey Howard not sure where you are located but these guys really seem to know the 700r pretty good and have some tech info about installing B&M shifters not sure but they might help. http://www.bowtieoverdrives.com/cata...BCAT&CATID=LA1
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
