Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
How can this starter work for 168 tooth???
Old Nov 12, 2011 | 03:25 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
http://www.ebay.com/itm/NEW-GM-SBC-B...item231608b265
Says it works for both 153 and 168. I use 168 and have a slanted bolt pattern but the one here has 4 holes all in a line. How is that supposed to work for 168? Anybody here use this kind of starter before?
Old Nov 12, 2011 | 04:17 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: How can this starter work for 168 tooth???
A lot of engine blocks have three holes so you can use a straight or a diagonal bolt starter. If yours is one of them, then that should work.
Old Nov 12, 2011 | 04:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
one set of holes puts the starter closer to the crank for the 153 tooth. the other holes space it father from the crank for the 168 tooth. you need the holes in line. doesnt work with the offset bolt holes.
Old Nov 12, 2011 | 05:23 PM
0pyders's Avatar
Oh ok I can use the other hole in the block I see. Thanks guys.
Old Nov 12, 2011 | 05:55 PM
travis401's Avatar
Car: 91 Camaro RS
also, the starter is clockable, you can take the 2 allen head screws loose from the mouting block and rotate the starter to keep it away from things like headers. ive got pretty much the same starter on my car. it also has a notch on the mounting block to clear the header flange.
Old Nov 15, 2011 | 03:10 AM
Abbass's Avatar
Should work if not you need the 153 tooth flywheel.chevy has two flywheels the tooth counts are 153 or 168,either one should work if the one you have doesnt work than the other will,
___________________
Windshield Replacement Phoenix
Old Nov 15, 2011 | 10:19 AM
travis401's Avatar
Car: 91 Camaro RS
the point of this starters design is it can be used with either 153 or 168....ive used the same starter on my 153 cars flywheel and for a short time on my trucks 168 tooth flexplate..
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
mhatfield 14
Oct 24, 2015 07:48 AM
milk
Aug 10, 2015 06:26 PM
