Pro-Comp heads and Air gap intake?
Sorry I am not sure where to run this thread but I have seen a lot of people talk about these heads in this forum. I am going to buy the Pro Comp 210 heads with the 64cc chambers. I have a 355sbc and I want to run an edelbrock Air Gap intake. Is this possible? I know the heads are slighty raised runner. But I have seen that people are using these type of intakes with the procomp heads.
PLease do not turn this thread into a "Pro Comp heads are garbage thread" These heads are going on a garbage motor so I am fine with using them!
Re: Pro-Comp heads and Air gap intake?
It says on their website that the fel-pro 1266 is the gasket to use! Will this gasket allow you to run the air gap type intake?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Be sure to check header clearance, those heads have a steep angle on the plugs.
Downward, more than the Corvette angle.
