TechRods Stand -Alone LT1 harness.
Car: 1987 Iroc-Z28
Engine: L98 (soon to be LT1)
Transmission: 700R4 (soon to be 4L60e)
Axle/Gears: 3.27 LS
Seen here --> http://www.ebay.com/itm/1996-97-LT1-...16%26rk%3D1%26
Has anybody used any of these? It looks well built and clean.
Just trying to get someone Else's opinion before I open my wallet.
Looks like the Harness is the perfect length to place the PCM under the dash like a factory 3rd gen.
Re: TechRods Stand -Alone LT1 harness.
Better to just modify a factory harness.
Car: 1992 camaro
Axle/Gears: 3:73
I have one works fine just do your self a favor get the one with the tranny plugins. It was a lot clearer then what I could do, only bad side is it takes about a month to get it.
It might work with the factory routing I went under the heater box they will extend the wires for $xx a foot.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Do I even need the VSS? I'm going to be using my factory mechanical gauges. and as for the trans plug.. I don't need it I'm running a 700R4 behind my LT1
My PCM will think its got a T56 behind it anyways.
gixxer92
04-12-2022 12:09 AM
88SS6SPEED
11-11-2015 07:05 AM
